Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 09-06-2015, 20:53   #1 (permalink)
Member: 1958357
Thanks Meter: 42
How to fix automatic com port disconnetion after setting pinout
HOW TO FIX AUTOMATIC COM PORT DISCONNETION AFTER SETTING PINOUT IN DETECT TAB. PLS I AM STILL LEARNING SIR
EXAMPLE
VOLCANO BOX PORT IS PORT 19
PINOUT PORT IS PORT 27
BUT THE PINOUT PORT DISCONNECTS AFTER SOME SECONDS PLS HOW DO I BYPASS THIS
For many phones, charge pins need to be set in order to identify USB devices.
Detecting D+ and D-...
Vcc: null
Gnd: 7
Detection initiated...
Found: D+ = 4, D- = 3
Detection D+/D- with 3.89 seconds!
Analyzing USB device, please wait...
Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
Detection completed.
Setting pinouts...
Find USB device:SPRD U2S Diag (COM27), (VID_1782&PID_4D00)
Pinout setting complete.
Available Ports:COM19 COM27
Old 09-07-2015, 07:46   #2 (permalink)
blacky199's Avatar
Member: 2030192
Thanks Meter: 1,334
Do step by step
Detection tab:
-select correct chip and correct pinout connection (rx,tx) (d+,d-)
-start detection
-after success detection pinout click set pinout
-after success set pinout remove mobile from volcano box by removing main pinout cable
Platform tab:
-select correct boot
-select your need ( read info , read flash etc...)
-untick auto detection pinout
-connect mobile with main pinout cable and press power button one time ( if port not opened click reset pinout ) then click start button
That's all
Old 09-07-2015, 08:15   #3 (permalink)
Member: 1958357
Thanks Meter: 42
Ok I will try it when I am back thanks
Sent from my Nexus 10 using Tapatalk
Old 09-07-2015, 12:07   #4 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
Hello ..
In Detect Tab use after find pin-out use pullup manually to Boot pin[Pin 4] ..
Click to Pullup & Set in Pin 4 ..
Also you can Press Boot key while pin-finding start ..
If Driver auto disconnect ..
Go to SPD tab /Select Boot/Untick Auto detect pinout ..
Now Press "Reset Pinout" [Driver will again Connect] & Do Run ..
If you Use Boot Cable or Modify Cable ..
Skip this Step ..
Just Do Untick Auto detect Pinout Connect Cable with Buttery ..
Port will Auto change in Port Box & Do Run ..
Regard'
AniAXN
The Following User Says Thank You to AniAxn For This Useful Post:
Old 09-07-2015, 14:50   #5 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,420
EXAMPLE
Vcc: null
Gnd: 7
Setting pinouts...
This Means You need To press boot key or try Manually Pin out And Set Pin #4 As GND Or Open Mobile And Short Tx or boot Pin With GND .
Old 09-07-2015, 18:34   #6 (permalink)
Member: 1958357
Thanks Meter: 42
Originally Posted by AniAxn View Post
Hello ..
Skip this Step ..
Regard'
AniAXN
Thanks very much it work very well.
Old 09-07-2015, 18:44   #7 (permalink)
Member: 1958357
Thanks Meter: 42
please i am still learning..... why do i get this error when i tried to write ORIGINAL FILE in an spd 6531 cpu which went dead after format
""Please change Boot or reduce Baudrate, try it again.
Ready to read/write again, please remove the power supply clip or battery and then re-loaded it.""
at this point i get confused. so what was i suppose to do. because reducing BAUDRATE did not work.
so pls how to fix this
Old 09-07-2015, 18:57   #8 (permalink)
Member: 1958357
Thanks Meter: 42
PLS I REALY NEED HERE IS THE SHOT
Old 09-07-2015, 21:06   #9 (permalink)
AniAxn's Avatar
Member: 1045758
Thanks Meter: 4,307
What status your phone now ..?
For Spd 6531 chip ..
Always Do work this way ..
  • Read Flash ..
  • Load backup & Do format ..
  • Next Write Backup ..
  • Again Do Format ..
If get any error try with Volcano 3.0.0 version ..
No one phone will die on this way ..
Regard'
Ani
Old 09-07-2015, 21:57   #10 (permalink)
Member: 1958357
Thanks Meter: 42
Ok.... Thanks very much. I am gratfull... One more question sir
Old 09-07-2015, 22:08   #11 (permalink)
Member: 1958357
Thanks Meter: 42
what about this sir how to bypass this issue
I tried to read file of phone but it stops without even reading the phone file.
Old 09-07-2015, 22:15   #12 (permalink)
Member: 1958357
Thanks Meter: 42
its stops at BAUD RATE ADJUST COMPLETE INSTEAD OF CONTINUE READING FILE.
pls dont say i should use New Version because it does not detect phone ( when press power key phone turns on instead of detecting. if there is a trick to fix this pls teach me)
only that particular version detects well. so pls help me.
phone problem: security code.
Old 09-08-2015, 04:23   #13 (permalink)
zoneofash's Avatar
Member: 1445819
Thanks Meter: 4,976
Smile
Select Boot #11 625A & Try Again
Old 09-08-2015, 08:14   #14 (permalink)
Member: 1958357
Thanks Meter: 42
Ok I will check it thanks
Page generated in 0.21249 seconds with 8 queries
