Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Volcano Box
Old 12-03-2012, 12:34   #1 (permalink)
aminnovelty's Avatar
Member: 566122
Thanks Meter: 254
How to format q mobile e-6
Dear supporter i got some qty of Qmobile E6 got user code,,, i just want to format or RESET all sets ,,, anybody can guide me that HOW TO FORMAT THESE NEW KIND OF Qmobile SETS ?
Old 12-03-2012, 12:47   #2 (permalink)
Latifkhan75's Avatar
Member: 1352180
Sonork: 100.1605782
Thanks Meter: 61
select boot 11 5.1232 tckk usb untick autopin find hold boot key press run insert usb cable install driver properly
Old 12-03-2012, 12:53   #3 (permalink)
Qaisar Mahmood's Avatar
Member: 226457
Sonork: 100.1604561
Thanks Meter: 14,879
try to MTK USB Method
go to detect tab
select cpu type (D+ D-) MTK USB & Mstar (Do Find Boot)
connect phone
click detect button
then click on set pinout
tick after Setting switches to platform
now go back to mtk tab
untick auto pinouts detect
Select Correct boot
select operation you want (format. read flash. write flash. imei tools)
and click run ( dont touch power button)
try and post result.
Old 12-03-2012, 13:03   #4 (permalink)
Member: 566122
Thanks Meter: 254
bhai can u tell me which one is BOOT KEY in E6,,?
Old 12-03-2012, 13:04   #5 (permalink)
Member: 566122
Thanks Meter: 254
thanks for ur reply ,,,, plz specify which one is BOOT KEY in E6 ? with thanks,,,
Old 12-03-2012, 13:11   #6 (permalink)
Member: 1352180
Sonork: 100.1605782
Thanks Meter: 61
(1) hold *+Power Button, (2) hold *+#, (3) hold 0+1,
(4) hold 0+2, (5) hold 2+5, (6) hold send key,
(7) hold Press 3, (8) hold 0 key + Power key,
(9) hold send key + 3
first of all check call button
Old 12-03-2012, 13:19   #7 (permalink)
Member: 566122
Thanks Meter: 254
khan sahib,,, thanks alot brother for your kind and comprehensive reply,,,, i got it sir.
Old 12-03-2012, 13:32   #8 (permalink)
Member: 1352180
Sonork: 100.1605782
Thanks Meter: 61
plz tell here witch is the correct boot key is call button because e440 boot key is call button and i hope e6 will has same
Old 12-03-2012, 13:38   #9 (permalink)
Member: 226457
Sonork: 100.1604561
try on Nokia 5310 USB Cable
1-untick auto detect pinout
2-Tick USB Mode
3-hold boot key
4-then insert USB Cable
See Solved Link
Qmobile E6 cant connect with volcano (Solved)
Old 12-03-2012, 14:19   #10 (permalink)
Member: 566122
Thanks Meter: 254
Thanks qaiser bhai DONE it ,,,
Old 12-03-2012, 14:21   #11 (permalink)
Temporary banned !!
Member: 1841569
Sonork: 100.1648551
Thanks Meter: 37
WHATS the boot key brother...??
Old 12-03-2012, 14:28   #12 (permalink)
Member: 566122
Thanks Meter: 254
I at the time of inserting USB cable ,,, i just slightly pre SEND key and insert cable ,,then gave MTK USB DRIVER,,,, after showing on device manager as MTK USB connected rest procedure done it,,,,
Old 12-03-2012, 14:30   #13 (permalink)
Member: 566122
Thanks Meter: 254
In the whole procedure,,, the main thing was to insert bat after inserting the cable with SEND switch pressed,,,
Old 12-25-2012, 08:05   #14 (permalink)
Member: 566122
Thanks Meter: 254
in all latest Q mobile ,,boot key is * ok
Page generated in 0.33711 seconds with 7 queries
