05-07-2015, 16:59 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 53
Member: 83397 Status: Offline Thanks Meter: 204 | Itel it1351e gmail account how to remove? [Solved] |
05-07-2015, 19:32 | #2 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Pakistan Age: 26
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | if adb is not on then safe method is find same model working pac file open volcano box android tab select pac file in file selection windows uncheck all only tick on userdata and cache and then write pac file. |
05-12-2015, 10:23 | #4 (permalink) |
Freak Poster Join Date: Feb 2015
Member: 2349975 Status: Offline Thanks Meter: 51 | It would have been safe if you had sent me a PM as i requested earlier. Now switch on USB DEBUGGING under setting(in DEVOLOPER OPTIONS) and ROOT phone then try write IMEI while phone is one. |
05-12-2015, 14:49 | #7 (permalink) |
Member: 83397 Status: Offline Thanks Meter: 204 | i have tried repair with volcano not working i have also noted that simcard not detected and base-band unknown maybe nv corrupted during flashing with research download |
05-12-2015, 17:03 | #8 (permalink) | |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Quote:
If Phone BaseBand Unknown ..!! You Need to Write Factory File Solve this issue .. Wbr, AniAXN Last edited by AniAxn; 05-15-2015 at 21:32. | |
05-15-2015, 06:53 | #11 (permalink) | |
Member: 83397 Status: Offline Thanks Meter: 204 | Quote:
i tried to flash bin file but stopped at nv finish. i tried another pc same problem Last edited by AniAxn; 05-15-2015 at 21:32. | |
05-15-2015, 21:37 | #12 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Try with Factory tool with Fac file ... Untick nv in setting tab & Do flash ... Wbr AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
05-16-2015, 06:35 | #13 (permalink) |
Member: 83397 Status: Offline Thanks Meter: 204 | solved by ResearchDownload_R2.9.9005 By AzimBahar . in Flash operations by tick Erase All flash and Active Flash. without ticking these settings flash failed. phone now work ok.thanks for your help |
