11-08-2012, 15:23 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: India,Chennai Super Kings..... Age: 33
Member: 1531954 Status: Offline Sonork: 100.1619337 Thanks Meter: 294 | how to solve ? i try to read flash write flash format this error only came also try all baudrate |
11-08-2012, 15:36 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Check Current flow with Eagle Eye whether it Drops, I think it's Hardware. If flow of Current Drops mean have to Check for Watelogs or Physical Damage to CPU. BR, ZUBER |
11-08-2012, 18:15 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | @ vignesharmy55 its flash id 100% supported in volcano if your phone is dead must check in hardware Br Qaisar mahmood |
11-09-2012, 05:58 | #5 (permalink) | ||
Member: 1531954 Status: Offline Sonork: 100.1619337 Thanks Meter: 294 | Quote:
this mobile still my hand i received the mobile condition is imei only | ||
11-09-2012, 09:34 | #8 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: Alaska
Member: 672931 Status: Offline Thanks Meter: 28 | Quote:
No solution if you not use that step. Format or Write Flash with imei broken will make phone dead. Write use backup file or other file from normal phone will not help. Perhaps later update write Imei on dead spd phone. | |
11-09-2012, 11:07 | #9 (permalink) | |
11-09-2012, 14:11 | #10 (permalink) |
Member: 672931 Status: Offline Thanks Meter: 28 | I know there is currently no solution for that problem Another time, check IMEI then try repair it before do another step Try search you will find a lot same case,... |
The Following User Says Thank You to OnyGSM For This Useful Post: |
