01-20-2015, 13:50 | #1 (permalink) |
Insane Poster Join Date: Nov 2014
Member: 2286075 Status: Offline Thanks Meter: 12 | How to unlock Samsung E1200R SPD ??? [Help] pllllllllllz need help to unlock ,Read flash,Format,.....Samsung SPD phones . can someone show me steps to do. is USB Cable enough to do these ??? Thanks |
01-20-2015, 14:42 | #2 (permalink) |
Product Manager Join Date: Jul 2009 Location: GsmGenesis
Member: 1084080 Status: Offline Thanks Meter: 8,204 | Check Here ;- http://forum.gsmhosting.com/vbb/f723...-code-1649218/ http://forum.gsmhosting.com/vbb/f723...ginal-1630376/ Regards MUKESH RAJ |
01-20-2015, 15:35 | #3 (permalink) | |
Member: 2286075 Status: Offline Thanks Meter: 12 | Quote:
with USB cable not work, i used Volcano JIGS,the phone detected & driver installed, But when i started to read Flash,after detecting phone and com port staied at :press the power on the phone... | |
01-20-2015, 15:45 | #4 (permalink) |
Member: 2286075 Status: Offline Thanks Meter: 12 | i tried again appears this log: Detection initiated... Vcc: 13 14 Gnd: 2 4 6 Analyzing D+ and D-... D+ = 16, D- = 17 Detection D+/D- with 1,34 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 11 Setting... Find USB device:SCI USB2Serial (COM826), (VID_1782&PID_4D00) Pinouts setting complete! Waiting for phone's response, press the Power on the phone... |
01-21-2015, 04:05 | #7 (permalink) | |
Member: 1084080 Status: Offline Thanks Meter: 8,204 | Quote:
Kindly use USB , and untick from Auto Detect Pinouts , CPU Chip Must be Selected SPD 6530 1. Change Baudrate to 115200 2. Press Home Key 3. Insert USB , You will A new Port 4. Read Flash / Write Flash / Unlock etc. See Here :- BR, MUKESH RAJ | |
01-21-2015, 14:00 | #8 (permalink) |
Member: 2286075 Status: Offline Thanks Meter: 12 | Yes Now is OK OK OKKKKKKKKKKK Because you help me BR,MUKESH RAJ with simple steps & correct guide. 1. Change Baudrate to 115200 2. Press Home Key 3. Insert USB , You will A new Port 4. Read Flash / Write Flash / Unlock etc. this is result: |
