11-04-2013, 08:46 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | How to Work..when (the phone has dual-flash ic) see here Hello All Members, Read Carefully How to Work with Chinese Mobiles having Dual Flash-Ic Inside If You work as described, u wont get your handset dead on doing any operation. First of All Read Its Info and see if it is 4mb ic, 8mb ic, 16mb ic etc. Read its Flash File in "Auto" with Baud rate 460800 setting like this and if not readed..change baud-rates 4mb Flash Ic handset will say Code: Size:0x400000(4MB) the phone has dual-flash ic,it reads flash size actually8(M) Code: Size:0x800000(8MB) the phone has dual-flash ic,it reads flash size actually16(M) Code: Size:0x1000000(16MB) the phone has dual-flash ic,it reads flash size actually32(M) (i.e. u got 8mb file of 4mb flash ic, 16mb file of 8mb flash ic, and 32mb flash file of 16mb flash ic) But remember these files are not Correct Flash Files and on writing them back you'll get your handset dead. Also you cannot revive your Dead Handset by these files. = = = = = = = = = = = = = = = = = = = * * * * * = = = = = = = = = = = = = = = = = = = = Question : How to Read Correct Flash File ? Answer : See here it is given below : Before Reading Flash File Make these Settings For 4mb flash ic - For 8mb flash ic - For 16mb flash ic - After Making these settings Read Your Flash File. Flash File Size will be Doubled again. (i.e. u got 16mb file of 4mb flash ic, 32mb file of 8mb flash ic, and 64mb flash file of 16mb flash ic) but Flash File just Readed is Very Correct..and on writing them back you'll get your handset alive. Best Regards - Moiz Khan (Smk™) |
The Following 7 Users Say Thank You to Moiz Khan For This Useful Post: |
11-04-2013, 09:51 | #2 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | How to Write Flash File ? Question : How to Write Flash File ? Answer : See here it is given below : Before Writing Flash File Make these Settings For 4mb flash ic, Select 16mb file backup & make this setting - For 8mb flash ic, Select 32mb file backup & make this setting - For 16mb flash ic, Select 64mb file backup & make this setting - After Making these settings Write Your Flash File... you'll get your handset alive back Best Regards - Moiz Khan (Smk™) |
The Following 4 Users Say Thank You to Moiz Khan For This Useful Post: |
11-04-2013, 14:25 | #4 (permalink) |
Freak Poster Join Date: Feb 2012 Location: nasipit
Member: 1720678 Status: Offline Sonork: yuki Thanks Meter: 20 | nice info sir but for me no need to change baudrate and flashsize just use VolcanoTool_v2.3.3 you can read and write dual flash size by not touching setting below let it auto only |
11-05-2013, 06:43 | #6 (permalink) |
Junior Member Join Date: Sep 2013 Location: bry, lagao General Santos City
Member: 2036792 Status: Offline Sonork: 104355643 Thanks Meter: 0 | i need help , BS Mobile G100 hang on logo ,,, i need help any solution pls ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, |
03-01-2014, 08:40 | #11 (permalink) | |
Freak Poster Join Date: Mar 2010 Location: In Search of free BB5 rpl
Member: 1248595 Status: Offline Sonork: 100.1607313 Thanks Meter: 99 | Quote:
03-19-2014, 13:38 | #14 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Bangladesh
Member: 1845954 Status: Offline Sonork: 100.1622497 Thanks Meter: 397 | Dear Moiz Khan Pls need right decission from u. Which is the right. About dual flash ic. Question : How to Read Correct Flash File ? Answer : See here it is given below : Before Reading Flash File Make these Settings For 4mb flash ic - Another thread u say If the size of readed file is 8mb, then Set the 'FLASH SIZE' Manually to 8mb and Read File again.(You'll get 16mb file now) Pls give right solution. Because in one thread u say about dual flash ic. If flash size is 4mb than manually to give 8mb. But another thread u say if flash size is 4mb han manually to give 4mb = If the size of readed file is 8mb, then Set the 'FLASH SIZE' Manually to 8mb and Read File again.(You'll get 16mb file now) |
