02-28-2014, 12:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | How to write IMEI in All SPD (Feature Phones + Android Phones) [Tutorial] How to write IMEI with VolcanoBox in All SPD Phones having P-05b Connector Before Repairing IMEI, User must follow these - User must have Win Xp (Service Pack 3) for best results Install Correct Drivers for your handset. If you dont have correct driver, then download from below links - SPD Android Usb Driver for win7/win8 (64bits) SPD Android Usb Driver for winXP/win7 (32bits) SC6530/6531/6610 New Usb Driver for win7/win8 (64bits) SC6530/6531/6610 New Usb Driver for winXP/win7 (32bits) Now Make These Settings - * Go to Detect tab & Select [D+/D-]SPD/Anyka in Detect Type. * Manually Drag n Drop pinouts (Pin2= D-) (Pin3= D+) (Pin5= GND) as given below - * After putting pins like this, Connect Handset on Volcano Main Cable. * Attach Power cables also & Press "Set Pinout" button. * After Pinouts Setting Complete, Remove Cable from Box Socket (Dont Remove Cables from Handset) See in pic below - Now do as stated here - Code: Step 1 - Open Volcano tool and go to spd tab and (Enable IMEI Option) Step 2 - Tick "Write IMEI" and Untick "Auto-detect pinouts" Step 3 - Set R/W IMEI to "COM" and press RUN Button(New Tool will Open) Step 4 - Select "USB" in ComP and Fill IMEI in boxes. Step 5 - Press "Write IMEI" button Step 6 - Now Connect the cable back to the BOX. Step 7 - wait for 2-3 minutes..you see message "Write IMEI done". >>> See here video Tutorial <<< NOTE : IMEI Changing is Illegal. Use this option only for restoring back corrupted IMEI. And that too on your own responsibility. Last edited by Moiz Khan; 07-12-2014 at 13:55. |
The Following 18 Users Say Thank You to Moiz Khan For This Useful Post: |
03-07-2014, 12:28 | #3 (permalink) | ||
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Quote:
and press set pinouts button. Quote:
Password - moizkhan786 bR. Smk Last edited by Moiz Khan; 07-12-2014 at 14:00. | ||
03-14-2014, 13:46 | #4 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | How to write IMEI in All SPD Phones having Other Connectors [Tutorial] How to write IMEI with VolcanoBox in All SPD Phones having Other Connectors Before Repairing IMEI, User must follow these - User must have Win Xp (Service Pack 3) for best results Install Correct Drivers for your handset. If you dont have correct driver, then download from below links - SPD Android Usb Driver for win7/win8 (64bits) SPD Android Usb Driver for winXP/win7 (32bits) SC6530/6531/6610 New Usb Driver for win7/win8 (64bits) SC6530/6531/6610 New Usb Driver for winXP/win7 (32bits) Now Make These Settings - * Go to Detect tab & Select [D+/D-]SPD/Anyka in Detect Type. OR You can Select [D+/D-]SPD/Anyka(Do find BOOT) in Detect Type.- OR Also You can Select [D+/D-]MTK USB&Mstar(Do find BOOT) in Detect Type.- * After this, Connect Handset on Volcano Main Cable and Attach Power cables also. * Press “Detect” button (Pinouts will get detected) * After detection, NOTE Pinouts and then press “Clear Pinout” button. * Now Manually Drag n Drop only these pins back to their places u noted – (USB D+) (USB D-) & (GND) * After this, Press "Set Pinout" button. * After Pinouts Setting Complete, Remove Cable from Box Socket (Dont Remove Cables from Handset) See in pic below - Now do as stated here - Code: Step 1 - Open Volcano tool and go to spd tab and (Enable IMEI Option) Step 2 - Tick "Write IMEI" and Untick "Auto-detect pinouts" Step 3 - Set R/W IMEI to "COM" and press RUN Button(New Tool will Open) Step 4 - Select "USB" in ComP and Fill IMEI in boxes. Step 5 - Press "Write IMEI" button Step 6 - Now Connect the cable back to the BOX. Step 7 - wait for 2-3 minutes..you see message "Write IMEI done". >>> See here video Tutorial <<< NOTE : IMEI Changing is Illegal. Use this option only for restoring back corrupted IMEI. And that too on your own responsibility. Last edited by Moiz Khan; 07-12-2014 at 13:56. |
03-15-2014, 15:05 | #5 (permalink) |
Freak Poster Join Date: Feb 2013
Member: 1891184 Status: Offline Thanks Meter: 3 | i follow the same procedue when i click on write imei and then i connect the cable to the box and wait 5 mint but still same ....means he said connect the phone or something like that but i did not see ant write imei done....i try 5 times Last edited by Moiz Khan; 06-16-2014 at 16:57. |
03-15-2014, 15:27 | #6 (permalink) | |
secondly.. if it got detected..then Note & Clear all pinouts Only Put these pins back (USB +) (USB D-) (GND) [By Drag n Drop method] Set pinouts...and then remove cable from box...follow given method post report. bR. | |
03-15-2014, 16:18 | #7 (permalink) | |
Member: 1891184 Status: Offline Thanks Meter: 3 | Quote:
03-15-2014, 18:32 | #8 (permalink) |
Member: 1891184 Status: Offline Thanks Meter: 3 | now the detecting is ok... i have solvethis problem but now the problem is when small box pop up..and i click on write imei button then he is not showing that connecting to the device after 10 sec button again ready for click... even that i also attach the cable and click on write imei then also no imei done...please check the image |
03-16-2014, 07:53 | #9 (permalink) |
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | Quote: also i can see drivers are incorrectly installed. contact me on sonork - 100.1627500 or yahoo msngr - [email protected] bR. Smk |
