04-12-2018, 09:23 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: sirajgonj, city
Member: 431935 Status: Offline Thanks Meter: 59 | Huawei Y3II LUA-U22 FRP Not Support 17:57:20 17:57:20 CUSTOM BOOT 17:57:33 DA File:LUA_L22_Boot.bin 17:57:33 DA Ver.:MTK_AllInOne_DA_v3.3001.00.00 17:57:33 17:57:33 Operation: 1. Power off the phone. 2. Please insert USB cable within 40 seconds. 17:57:33 17:57:46 PreLoader USB VCOM (Android) (COM50) 17:57:46 17:57:47 Connecting... 17:57:47 CPU TYPE:MT6582 17:57:47 Hardware version:CA01 17:57:47 Software version:0001 17:58:00 SecCfgVal :0x00000000 17:58:00 BromVersion :0xFF 17:58:00 BLVersion :0x01 17:58:00 Boot downloading... 17:58:03 EMMC_ID:0x90014A483847316505074EF2218914E9 17:58:03 EMMC_PRODUCT_NAME: 0x483847316505 17:58:03 EMMC_BOOT1_SIZE: 0x00400000 17:58:03 EMMC_BOOT2_SIZE: 0x00400000 17:58:03 EMMC_PRMB_SIZE: 0x00400000 17:58:03 EMMC_GP1_SIZE: 0x00000000 17:58:03 EMMC_GP2_SIZE: 0x00000000 17:58:03 EMMC_GP3_SIZE: 0x00000000 17:58:03 EMMC_GP4_SIZE: 0x00000000 17:58:03 EMMC_USER_SIZE: 0x1D2000000(7.28 G) 17:58:03 17:58:03 INT RAM: 128KB SDRAM EXT RAM: 1GB DRAM 17:58:03 Finding partition. 17:58:03 Create temp file failed, the program has terminated. 17:59:30 Current Task: Clear FRP 2(EMMC) Need Support it |
04-12-2018, 13:01 | #2 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Bangladesh
Member: 1845954 Status: Offline Sonork: 100.1622497 Thanks Meter: 397 | 100% support this model. Process:- 1. Open inferno MTK 2. Select Custom boot 3. Select Clear FRP 2 EMMC 4.Select this file 5. Connect cable w/o press any button Thats Ok Bro, cms_shamim |
The Following 3 Users Say Thank You to gsm_shamim For This Useful Post: |
04-12-2018, 14:56 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: KARACHI PAKISTAN Age: 45
Member: 207561 Status: Offline Thanks Meter: 820 | 1. Open inferno MTK 2. Select Custom boot 3.Clcik Tab Unlock phone 4.Click Unlock USB 5.Click Clear FRP 2 EMMC 6.Click OK 7. Select Boot File LUA_U22_Boot 8.inset cable 9.once more select boot FILE 10.Done FOLLOW VDO. THANKS https://www.youtube.com/watch?v=7AhoPG_8WV8 |
The Following 3 Users Say Thank You to love_4all For This Useful Post: |
04-12-2018, 18:48 | #5 (permalink) |
Freak Poster Join Date: Mar 2015
Member: 2362072 Status: Offline Thanks Meter: 46 | [QUOTE=souravhasan;13074962]WHEN I OPEN LUA-U22 folder then i saw LUA_L22_Boot.bin what can i do...[/QUOT See carefully gsm_shamim give file in his post |
The Following User Says Thank You to xxyy For This Useful Post: |
04-13-2018, 05:46 | #6 (permalink) | |
Freak Poster Join Date: Aug 2011
Member: 1634244 Status: Offline Thanks Meter: 143 | [QUOTE=xxyy;13075425] Quote:
it is ok to try other boot files as long as it is the same cpu boot file, it is a matter of trial and searching working boot files, once it reads full info after loading custom boot, files can be said compatible and working.....there are intance that full info can be read but cannot reset frp, format or read phones back up files, that means it requires second loader or auth. files...mostly DA_SWSEC.sys will work. | |
The Following User Says Thank You to wintertrop For This Useful Post: |
