06-10-2015, 21:15 | #1 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | I can not repair IMEI Alcatel null MT6572 Please I need to know if it is possible to repair imei this phone? thanks mfeliu07 Quote:
06-10-2015, 23:47 | #2 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Pakistan Age: 26
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | Hello First Of all chk baseband if baseband is not ok then repair baseband first if baseband is ok then Use Volcano 3.0.0 and Repair Imei In Android tool Mode 1 and also u can try mode 2 or 3 to repair in adb mode [phone must be rooted] or For Better Result Use Merapi Tool If ANy Eror Post Logs Or screenshorts here we try to solve ur problem |
The Following User Says Thank You to masterRt1994 For This Useful Post: |
06-11-2015, 07:52 | #3 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hello .. First Do Root Your Phone & Run Volcano 3.0.0 Android Tool[USB Mode] .. Select Mode 3 & Do Repair[Phone Must be Power On Condition] Try with this way .. If Fail Check your Phone Baseband .. Post Result .. Wbr, AniAXN |
The Following 3 Users Say Thank You to AniAxn For This Useful Post: |
06-13-2015, 15:26 | #4 (permalink) | |
Member: 517318 Status: Offline Thanks Meter: 88 | hello thanks for help, I do all the process but does not repair the IMEI. Try Mode 2 and Mode 3. They can suggest another possible solution. thanks mfeliu07 Quote:
06-13-2015, 20:17 | #5 (permalink) |
No Life Poster Join Date: Jan 2013 Location: India
Member: 1873645 Status: Offline Thanks Meter: 977 | @mfeliu07 Hello Bro..Mode 2-3 for adb based IMEI Repair. You Can Repair IMEI With Mode 1 and 4. it will be batter 1.turn of mobile. 2.tick on write imei and select mode 1 3.fill imei ( do not change imei ) 4.press start 5.now battery battery in device .keep device off. 6.now plug usb cable and wait for detect and repair imei{ this option Must need install CDC driver } BR |
The Following User Says Thank You to laxmi kamlesh For This Useful Post: |
