08-12-2014, 15:17 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Saudi Arabia Age: 45
Member: 417778 Status: Offline Sonork: 100.1603326 Thanks Meter: 116 | i need help regarding chinese Tab i am failed several time to connect or read pass codes or Reset Google account with volcano box , now i have a Chinese TAB for read or reset Google account so how can i reset the Google account with volcano box.] hare is the description about TAB Model Name : Q-Wave 70BK quantum.net S/: QW700001013161018 need help to solve this problem . Last edited by adnan_taeki; 08-12-2014 at 15:22. |
08-12-2014, 21:21 | #4 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hi ... As you say your TAB is Rochchip CPU inside ... Your TAB only support with Volcano using ADB Mode .. So first you Connect usb cable to TAB & see in Device Manager.. Is you TAB Connect with ADB Mode or not ... If connect then you can Do Root & Wipe or Gmail lock using Volcano .. If TAB USB Debug on Then follow this way ...
If your TAB USB Debug off ... You can't do anything without IMEI Rebuild with Volcano .. Because Rockchip not support read , write or format with volcano or any other tool .. That time You need Only Factory File or Toll .. Note - You must know that all of Android phone or Tab which have any CPU inside , If thos USB Debug On Then you can Do Root , wipe , unlock, backup NV , unroot ...it's all Fully Supported with Volcano for a Long time .. Wbr, AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
08-13-2014, 07:20 | #5 (permalink) |
Member: 417778 Status: Offline Sonork: 100.1603326 Thanks Meter: 116 | ok bro but the tab when i connect with computer it is connected as storage device , usb debug is not enabled . and what do you mean about rebuild imei " you cannot do anything without rebuild imei" please explain. Regards ADnan |
08-13-2014, 10:10 | #6 (permalink) | |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Quote:
You can Only Change Imei in Rockchip cpu using Volcano ... Got it Bro ....? Wbr, AniAXN | |
08-13-2014, 11:42 | #7 (permalink) |
No Life Poster Join Date: Aug 2012 Location: India Age: 39
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | Rockchip CPU Solution Pattern Lock/user lock / Gmail account bypass without Flashing Tablet Pc firmware. (Method tested by myself on many Tablets, work 100% perfect) tool RockChip Android Tool - Download - 4shared - sham zaheer Connect your android tablet in boot mode .(There is many bootmood for Rockchip ). Most common is Turn off your tablets , Press and hold volume (-)down button and insert cable. Rockchip Android Tool Extract software with winrar Run Software ,Uncheck all boxes if checked [IMG]http://1.bp.********.com/-IzA0Lr2bRdg/UrbQ_h5RatI/AAAAAAAAAWA/dnvGCs_BG-g/s1600/Capture15.JPG[/IMG] Check only Option 3 [IMG]http://3.bp.********.com/-ClJ9XHdJfNc/UrbQ_53XVwI/AAAAAAAAAWI/-Oe5Cf3jasM/s1600/Capture17.JPG[/IMG] Click on Box [IMG]http://1.bp.********.com/--crZFp5pjlA/UrbQ_3rjszI/AAAAAAAAAWE/zZJpZn9QYE4/s1600/Capture16.JPG[/IMG] A pop up window will appear , Select misc (as i have mentioned) [IMG]http://3.bp.********.com/-jCZEwkjEetA/UrbRASxG0RI/AAAAAAAAAWY/Tj31KwbYrCE/s1600/Capture18.JPG[/IMG] Select img file and Run software [IMG]http://2.bp.********.com/-oX3MnAR5GVw/UrbRAoPaPNI/AAAAAAAAAWc/-2TCLOB3tqY/s1600/Capture19.JPG[/IMG] Wait for few seconds . Android tablet will be restart and you are done . This is tested method . I have personally use this software with many Rockchip Tablets based on RK3066,Rk2928 and it was successful,and works like charm . br umesh gaba |
The Following User Says Thank You to Umesh_Arora For This Useful Post: |
10-08-2014, 07:19 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2007 Location: Palestine
Member: 452256 Status: Offline Sonork: 100.1651051 Thanks Meter: 587 | you are a grate man bro its done like you said thanks from my hart |
The Following User Says Thank You to .::Naseer Al-islam::. For This Useful Post: |
