01-24-2014, 21:31 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Uruguay
Member: 980958 Status: Offline Thanks Meter: 16 | I need help to work with processor SC6531C I can not work it in any way. Try USB and the computer turns on. Try to COM port and not detected. Try direct to plate welded and not finish reading the info cell. |
01-25-2014, 04:36 | #2 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Brother try to use usb cable ... Don't use volcano main cable... Select boot 15 .. untik auto pin out detect .. Select read , write etc .... Do run ..When software sey ..analyzing usb .. Press boot key( vol+\ vol-\home key\other) & connect to usb ... Try it first & post result .... Br, AniAXN |
01-25-2014, 05:10 | #4 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Manila,Philippines
Member: 1536588 Status: Offline Sonork: 100.1613366 Thanks Meter: 480 | This bug use dragon to connect theN format volcano SAME CPU LOOK http://forum.gsmhosting.com/vbb/f646...ading-1770032/ |
01-26-2014, 20:46 | #5 (permalink) |
Member: 980958 Status: Offline Thanks Meter: 16 | I can not get results with this cell. Try using USB cable "special" connector to PC detects a port COM98 me, destildo auto-detect frame read flash, click RUN but does nothing. |
01-26-2014, 21:14 | #6 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Brother ... Fallow step by step ... Select boot 15 ... Click to read flash. .. Untik "Auto pin out detect" .... Insert Battery in Phone ... Press boot key ..like ...vol+, vol-, home key, vol+vol- both press.. Connect usb cable derect to PC .. If you prees wrong key ..phone show to charging or other.. Find correct boot key first. . When you prees proper boot key .. Phone not come in charging mode..then you see volcano port box. Port will change..still press boot key .. Now you can click to read , write & run until press boot key .. Or if you hsve modify cable no need to press boot key Just connect & do job ... Try it & post result with screen shot .... Br, AniAXN |
01-27-2014, 04:50 | #7 (permalink) | |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | Quote:
Just Untick mark auto detect pinouts Select phone port And press run button And for next job you need to again connect phone | |
