Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 11-24-2014, 02:20   #1 (permalink)
Member: 762446
Thanks Meter: 13
i need solution when i write spd 6531 stuck 0%[Solved]
i need solustion when i flashing venera 125 spd 6531
i need solution?
Old 11-24-2014, 05:27   #2 (permalink)
Member: 1217358
Sonork: 100.1605541
Thanks Meter: 156
change your flash file and try.................
The Following User Says Thank You to alpona_su For This Useful Post:
Old 11-24-2014, 07:04   #3 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
its flash file problem please change the file
The Following User Says Thank You to sweet4hamza For This Useful Post:
Old 11-24-2014, 08:07   #4 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
Hello ...
For Spd6531 ..
Use Next time Volcano 2.7.2 ...
Follow this Step ..
Detect pin-out ..
Set Pin-out in Detect Tab ..
Then Go to Spd Tab ..
  • Do Read Flash ..
  • Next do Format ..
  • Next Write Back up Flash ..
  • Again Do Format ..
Note - For Itch Step you need to reconnect driver again press "reset Pin-out"
Batten .. Don't use auto detect pin-out ..
Wbr,
AniAXN
The Following 4 Users Say Thank You to AniAxn For This Useful Post:
Old 12-08-2014, 10:12   #5 (permalink)
Member: 762446
Thanks Meter: 13
thax to all master problem solved
Old 12-08-2014, 12:32   #6 (permalink)
AniAxn's Avatar
Member: 1045758
Thanks Meter: 4,307
Happy to see your success ..
Thread Close
Page generated in 0.17306 seconds with 8 queries
