10-15-2015, 17:10 | #121 (permalink) | |
Insane Poster Join Date: Aug 2006 Location: Pakistan,Bahawalpur
Member: 329994 Status: Offline Thanks Meter: 14 | Quote:
The Following User Says Thank You to Nomi1987 For This Useful Post: |
10-19-2015, 13:31 | #122 (permalink) |
Freak Poster Join Date: May 2014 Location: Al-Bakistan
Member: 2191194 Status: Offline Thanks Meter: 75 | Wiko Lenny full dead recover done with KCOLO Pinout Wiko Lenny mobile hang on logo .full dead after flash with low ver file. and not detect to pc. .... recover done after help of this complete post. http://forum.gsmhosting.com/vbb/f723...boots-1658331/ thanks to all team and "Faisal_Computer" |
10-19-2015, 13:53 | #123 (permalink) | |
Member: 2191194 Status: Offline Thanks Meter: 75 | Quote:
http://forum.gsmhosting.com/vbb/f728...-need-1904795/ | |
11-12-2015, 22:26 | #128 (permalink) |
Insane Poster Join Date: Oct 2013 Location: phils
Member: 2047969 Status: Offline Thanks Meter: 9 | ive follow all the instructions Above ., my phone now recognized my PC but, insted of vcom preloader, mtk usb port only.... can you help me on how to forced preloader of this mtk device phone of mine.... ive already install pda vcom net and Driver_Auto_Installer_v1.1236.00.... but i cant get into preloader. so that i can flashed it with my stock rom... thanks..... |
11-14-2015, 08:59 | #129 (permalink) |
Freak Poster Join Date: Jan 2014 Location: pakistan sheikhupura
Member: 2114706 Status: Offline Thanks Meter: 36 | hy bro i have I9060 MTK 6572 clone i flashed with one file the phone is dead now i try with alot of files not working even the back up not writing . plz help me Now phone only taking info woth volcano box nothing doing more |
11-16-2015, 05:40 | #130 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2463999 Status: Offline Thanks Meter: 0 | Hie One thing you can do is to open up your phone. Remove the shell covers. On the PC board look for GRV Golden point and also KCold golden point. Get a soldering gun and solder copper wire to connect the two points. If you can flashed without the battery, then run SP Flash Tool and load the backup scatter file. Click download on the SP flashtool and connect usb cable to your phone and it should start the flash process. Once down load process finishes remove usb cable, de-solder the wire you connected two golden points. re-assembled all shell covers and put back the battery. Your phone should start up. |
11-16-2015, 07:16 | #131 (permalink) |
No Life Poster Join Date: Apr 2015 Location: FLORENCE ITALY
Member: 2375239 Status: Offline Sonork: 100.1662985 Thanks Meter: 962 | today i have recive q mobile a12 fone was dead in wrong flash when i read info the fone on volcano fone was always comport error so i done this after formate the fone with volcano fone is alive now boom boom volcano box |
11-17-2015, 05:50 | #133 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2487938 Status: Offline Thanks Meter: 0 | Micromax A110 Partially Dead!! I have a Micromax A110 that uses : H/W Ver. : V1.0 S/W Ver. : V1.11 I think there is a matter of unstable COM port in this phone, As per Faisal_Computer told, I disassembled my phone and sought "COLO" or "KOLO" or "KCOLO" and ended up with DP, DM, TX, RX, OE, VCHG (nearby the camera) and G, V (nearby Battery Connector). I find out somewhere in a forum that I can flash it if I short or solder DP, DM to RX, TX, is it an alternate method to make a stable COM Port as soldering KCOLO/KOLO to GND is. If not, Please tell me which points should I suppose to short. Thank you. |
11-17-2015, 06:13 | #134 (permalink) | |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Quote:
Short KCOLO/COLO Point With GND And Flash PRELOADER Patition Only With Usb.After Flash Preloader Remove KCOLO/COLO jumper And Flash Your Phone Normally With All Partitions. | |
11-17-2015, 06:16 | #135 (permalink) | |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
