04-17-2015, 16:49 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: burkina faso
Member: 457765 Status: Offline Thanks Meter: 77 | Illegal use vinko m8 THIS PHONE I HAVE ILLEGAL USE AND SHUT DOWN HERE IS PHONE LOG AFTER BACK UP AND WRITE AGAIN; Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310001] FLASH ID: 00EF006000170000 Flash Type: SF_W25Q64DW Size:0x800000(8MB) Writing completed. >>Flash file C:\Documents and Settings\dao\Bureau\hhhhhhhhhhh has been written. |
04-17-2015, 17:30 | #2 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Banjul, The Gambia
Member: 1974557 Status: Offline Sonork: 00011nd Thanks Meter: 39 | Bro, explain very well, what problem do you have with that. if your problem is llegal use shut down, which means you have privacy lock inside the phone. Do read back up after you tick unlock. use the readed password to resset the phone to factory and post result |
04-17-2015, 18:07 | #3 (permalink) |
No Life Poster Join Date: Sep 2013 Location: India
Member: 2030192 Status: Offline Thanks Meter: 1,334 | way 1 -read backup -do format -write backup way 2 -find same good working mobile or find good file on internet -take backup -write good file your problem will be solved if imei damaged do imei repair same imei as on mobile sticker |
04-18-2015, 06:37 | #4 (permalink) | |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
