12-20-2013, 17:54 | #1 (permalink) |
Freak Poster Join Date: Dec 2011 Location: india
Member: 1701545 Status: Offline Thanks Meter: 100 | imei cant repair of samsung grand Done By Rahul_Bhutani Help ;) n 2 step try but some condiotn any one help me Connecting, Please Wait... Found Device...0123456789ABCDEF Model = GT-I908 OS Version= 2.3.6 CPU TYPE = mt6575 CPU TYPE 2= MT6575 Model= ALPS.GB2.MP.V2.21 Device Info 1= MAUI.11AMD.W11.50.SP.V30.P2, 2013/04/23 16:21 Display ID= lcsh75cu_gb2 SIM CARD IS READY... IMEI 1= 359885555555555 IMEI 2= 359855555555555 Running data do not touch phone... Please Switch off device and switch on again?? Waiting for device to connect... Rechecking Imei Found Device...0123456789ABCDEF IMEI 1= 359885555555555 IMEI 2= 359855555555555 Write IMEI done, reboot please. pls volcano team tell me how to repair this set |
12-20-2013, 18:03 | #3 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | MTK 65xx New Method for imei repair how to repair imei ? go to MTK TAB do Enable imei click on Android tool click on Run click on MTK 65xx New Method Fill imei in boxes click on Write imei when software saying searching for port Insert Usb cable to phone in powered OFF condition !! install cdc drivers waiting software for process complete after 2 secs your imei repair |
12-20-2013, 18:14 | #4 (permalink) | |
Member: 1701545 Status: Offline Thanks Meter: 100 | i try this but some condion Quote:
1.Select the mobile's USB debugging. 2.Please input 15 bits of IMEI and click button Write IMEI. 3.When software shows Searching port,please power off mobile phone with battery inside and connect to box with cable. COM port searching and preloader handshake. Connect port COM78. COM port searching and preloader handshake. Connect successfully. CPU TYPE:MT6575 DSP Firmware Version: DSP Patch Version: Software Version:MAUI.11AMD.W11.50.SP.V30.P2 Hardware Version:LCSH15CU_HW Audio Version:Unknown IMEI1:359885555555555 IMEI2:359855555555555 IMEI success. >>Write IMEI done. | |
12-21-2013, 05:05 | #7 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,976 | If You Want To Change Imei 1st Open Latest Model Go To Android Tab Then Try To Change < If Same Then 1st Root Then Try Again Using Android Tools How To Repair MTK Android (65XX) IMEI With Android Tools : Some preparations for operation 1.Insert phone SIM card 2.Power on phone please 3.Turn off flight mode 4.Phone USB mode is enabled How To Repair MTK Android (65XX) IMEI :
If You Need CDC Driver : Android_Gadget_CDC_driver Or mtk android cdc and vcom.rar Samsung Galaxy S4 GT-I9500(Copy)Ver4.2.2 IMEI Repair & IMEIChange Done With Volcano IMEI Write Done Br AzimBahar |
12-21-2013, 08:28 | #8 (permalink) | |
Member: 1701545 Status: Offline Thanks Meter: 100 | some conditoin after this tool use Quote:
pls tell me Available Ports:COM1 COM2 COM20 COM65 COM66 Current Port:COM66 COM port searching and preloader handshake. Connect port COM78. COM port searching and preloader handshake. Connect successfully. CPU TYPE:MT6575 DSP Firmware Version: DSP Patch Version: Software Version:MAUI.11AMD.W11.50.SP.V30.P2 Hardware Version:LCSH15CU_HW Audio Version:Unknown IMEI1:359885555555555 IMEI2:359855555555555 >>IMEI success. | |
12-21-2013, 08:30 | #9 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,976 | Did You Try With Android Tools ? If Not Flow My Gide Then Post Result . 1st root Then Try With Android Tools If Not Done Post With Screenshots Of Android Tools Br Azimbahar |
