karbonn a51 problem [Solved] hello how to connect a karbonn a51 please s/w found only GRND no rx tx with volcano any1 try this??? |
salect spd cpu 6810/8820 try to connect not done use modyfy usb magic cable your problem solv 100% br |
conect with vol(- ) button and set pin out. only usb is working fine. |
This spd Andriod phone , can not connect with rx tx , you must need connect it via USB cable , try with boot key Or use modified cable |
hello support i modified the cable and install driver sucessfully. now how to proceed with gmail a/c please?? |
karbonn a51 Quote:
@ khem try this and let me know http://forum.gsmhosting.com/vbb/10114394-post6.html BR Qaisar Mahmood |
re hello check this if all is ok:
cant read info, please help me!!!!!!! |
@ khem .... Bro Just go to ...
just like that ... http://img198.imageshack.us/img198/8366/bk1.bmp Br, AniAXN;) |
first insert magic cable (When new com port formed) Press RUN Button. post report. bR. |
http://s9.postimg.org/hcu1gwg9r/ujjool.png still cant read info.. please check the port if ok or not!! Thanks |
ok done!!!!!!!!!!!!! by power on and vol + and insert usb cable phone shud be on usb2serial ;) BR KHEMAL BAYJOU Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100001] Flash ID: 00EC00BC00555400 Flash Type:[SAMSUNG] K9F4G08/K9K4G08 FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 250m(system),130m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic),512k(simlock),10m(intmemory) Analysis flash internal data successfully. Waiting for phone's response, press the Power on the phone... Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00EC00BC00555400 Flash Type:[SAMSUNG] K9F4G08/K9K4G08 FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 250m(system),130m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic),512k(simlock),10m(intmemory) Analysis flash internal data successfully. >>Set to Factory successfully. |
Happy to see problem solved Topic closed now |
