Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Volcano Box
Old 02-16-2014, 21:27   #1 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
Thanks Meter: 297
Question karbonn a51 problem [Solved]
hello
how to connect a karbonn a51 please
s/w found only GRND no rx tx with volcano
any1 try this???
Old 02-17-2014, 04:13   #2 (permalink)
Anant_Chavan's Avatar
Member: 1649027
Thanks Meter: 56
salect spd cpu 6810/8820 try to connect not done
use modyfy usb magic cable your problem solv 100%
br
The Following User Says Thank You to Anant_Chavan For This Useful Post:
Old 02-17-2014, 05:31   #3 (permalink)
Member: 1080792
Sonork: 4d0ddc25d0db862fb2f2b62f1
Thanks Meter: 31
conect with vol(- ) button and set pin out. only usb is working fine.
The Following User Says Thank You to sitaramkantheti For This Useful Post:
Old 02-17-2014, 05:40   #4 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,367
This spd Andriod phone , can not connect with rx tx , you must need connect it via USB cable , try with boot key
Or use modified cable
The Following User Says Thank You to sweet4hamza For This Useful Post:
Old 02-21-2014, 21:17   #5 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
Thanks Meter: 297
hello support
i modified the cable and install driver sucessfully.
now how to proceed with gmail a/c please??
Old 02-22-2014, 03:16   #6 (permalink)
Member: 1107485
Thanks Meter: 72
karbonn a51
Originally Posted by khem View Post
hello support
if phone is connect your volcano box and pc then first go to spd tab,salect boot spd cpu 6810/8820, unchek auto-detect pinouts,read info.. second tic format tab and click run....after set will restart and your problem will solve...thanks..
Old 02-22-2014, 06:09   #7 (permalink)
Qaisar Mahmood's Avatar
Member: 226457
Sonork: 100.1604561
Thanks Meter: 14,898
@ khem
try this and let me know
Qaisar Mahmood
Old 02-23-2014, 14:58   #8 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
Thanks Meter: 297
Question
re hello
check this if all is ok:
  • a51 connected and driver ok com 30/31..
  • spd tab..
  • salect boot spd cpu 6810/8820, (NOT FOUND THIS)i select another one, please check the picture i will upload:..
  • unchek auto-detect pinouts..
cant read info, please help me!!!!!!!
Old 02-23-2014, 15:05   #9 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
Thanks Meter: 297
Old 02-23-2014, 15:09   #10 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 3,685
@ khem ....
Bro Just go to ...
  • SPD Tab ...
  • Select Boot 14 ...(6820/8810)...
  • UN tick Auto Detect Pin out ...
  • Click read info ... & Do Run ...
  • If Chip supported ...
  • Do Format ....
  • If Analyses fail ...
  • Don't Do Format ..
just like that ...
Br,
AniAXN
Old 02-23-2014, 15:27   #11 (permalink)
Moiz Khan's Avatar
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,223
Arrow
After making these settings, dont press "RUN" button
first insert magic cable
(When new com port formed) Press RUN Button.
post report.
bR.
Old 02-23-2014, 22:19   #12 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
Thanks Meter: 297
still cant read info..
please check the port if ok or not!!
Thanks
Old 02-23-2014, 22:30   #13 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
Thanks Meter: 297
ok done!!!!!!!!!!!!! by power on and vol + and insert usb cable
phone shud be on usb2serial
KHEMAL BAYJOU
Internal version: SPRD3
Boot downloaded.
Start boot please wait a moment....
Spreadtrum Boot Block version 1.1
Boot downloaded.
CPU TYPE:SC8810/6820 [88100001]
Flash ID: 00EC00BC00555400
Flash Type:[SAMSUNG] K9F4G08/K9K4G08
FLASH LEN:0x20000000
mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 250m(system),130m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic),512k(simlock),10m(intmemory)
Analysis flash internal data successfully.
Waiting for phone's response, press the Power on the phone...
Boot downloaded.
Boot downloaded.
>>Set to Factory successfully.
Old 02-24-2014, 05:17   #14 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,367
Happy to see problem solved
Topic closed now
Page generated in 0.31836 seconds with 7 queries
