07-23-2015, 07:50 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: SURESH ELECTRONICS, INDIA Age: 49
Member: 216081 Status: Offline Sonork: 100.1614205 Thanks Meter: 55 | Karbonn k34 star spd6531 format failed 2015-07-23 12:03:44 PM >>Connecting... 2015-07-23 12:03:48 PM >>Connection successful,connected state! 2015-07-23 12:03:48 PM >>Version: V3.8 2015-07-23 12:03:48 PM >>SN:185-xxx-0xx 2015-07-23 12:03:48 PM >>Port:COM3 2015-07-23 12:03:49 PM >>After format or Flash you have to press & hold power button for at least 1.30 mins. 2015-07-23 12:03:49 PM >>Note for win7 users : 2015-07-23 12:03:49 PM >>Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. 2015-07-23 12:03:49 PM >>After that the spd drivers will have the ability to be loaded. 2015-07-23 12:03:50 PM >>Available Ports:COM3 2015-07-23 12:03:50 PM >>Current Port:COM3 2015-07-23 12:08:43 PM >>Available Ports:COM3 2015-07-23 12:08:43 PM >>Detection initiated... 2015-07-23 12:08:44 PM >>Vcc: null 2015-07-23 12:08:44 PM >>Gnd: 5 2015-07-23 12:08:44 PM >>Analyzing D+ and D-... 2015-07-23 12:08:48 PM >>D+ = 3, D- = 2 2015-07-23 12:08:48 PM >>Detection D+/D- with 3.63 seconds. 2015-07-23 12:08:48 PM >>Continue to detect BOOT pin... 2015-07-23 12:08:54 PM >>Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) 2015-07-23 12:08:54 PM >>UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 2015-07-23 12:08:54 PM >>Setting... 2015-07-23 12:08:59 PM >>Find USB device:SCI USB2Serial (COM27), (VID_1782&PID_4D00) 2015-07-23 12:08:59 PM >>Pinouts setting complete! 2015-07-23 12:08:59 PM >> 2015-07-23 12:08:59 PM >> 2015-07-23 12:08:59 PM >>Internal version: SPRD3 2015-07-23 12:09:00 PM >>Boot downloading... 2015-07-23 12:09:01 PM >>Start boot please wait a moment.... 2015-07-23 12:09:05 PM >>Spreadtrum Boot Block version 1.2 2015-07-23 12:09:05 PM >>CPU TYPE:SC6531 [65310001] 2015-07-23 12:09:05 PM >>FLASH ID: 00C8006000160000 2015-07-23 12:09:05 PM >>Flash Type: SF_GD25LQ32 2015-07-23 12:09:05 PM >>Size:0x400000(4MB) 2015-07-23 12:09:08 PM >>Reading...(0) 2015-07-23 12:09:28 PM >>The data has been saved in D:\Users\Suresh Babu\Desktop\_20150723_120924_FullFlash.bin, size: 4 M. 2015-07-23 12:09:34 PM >>Detection initiated... 2015-07-23 12:09:34 PM >>Vcc: null 2015-07-23 12:09:34 PM >>Gnd: 5 2015-07-23 12:09:34 PM >>Analyzing D+ and D-... 2015-07-23 12:09:38 PM >>D+ = 3, D- = 2 2015-07-23 12:09:38 PM >>Detection D+/D- with 3.63 seconds. 2015-07-23 12:09:38 PM >>Continue to detect BOOT pin... 2015-07-23 12:09:44 PM >>Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) 2015-07-23 12:09:44 PM >>UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 2015-07-23 12:09:44 PM >>Setting... 2015-07-23 12:09:49 PM >>Find USB device:SCI USB2Serial (COM27), (VID_1782&PID_4D00) 2015-07-23 12:09:49 PM >>Pinouts setting complete! 2015-07-23 12:09:49 PM >> 2015-07-23 12:09:50 PM >>Internal version: SPRD3 2015-07-23 12:09:50 PM >>Boot downloading... 2015-07-23 12:09:52 PM >>Start boot please wait a moment.... 2015-07-23 12:09:55 PM >>Spreadtrum Boot Blo~ 2015-07-23 12:09:55 PM >>CPU TYPE:SC6531 [65310001] 2015-07-23 12:09:55 PM >>FLASH ID: 00C8006000160000 2015-07-23 12:09:55 PM >>Flash Type: SF_GD25LQ32 2015-07-23 12:09:55 PM >>Size:0x400000(4MB) 2015-07-23 12:09:58 PM >>The 1st boot failure,Please reduce Baud-rate and try again! tried all baud rate, unable to write read file, same error need original flash file. or any other solution. Thanks |
07-23-2015, 07:58 | #2 (permalink) | |
Freak Poster Join Date: May 2014 Location: In the Chip Level
Member: 2187058 Status: Offline Thanks Meter: 41 | Quote:
Make Baud Rate to highest 1843200 and post the screen short If device restarting condition or dead, then, try with working flash file. WBR Micro Mind | |
07-23-2015, 09:44 | #3 (permalink) |
Member: 216081 Status: Offline Sonork: 100.1614205 Thanks Meter: 55 | Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 3.70 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM27), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Blo~ CPU TYPE:SC6531 [65310001] FLASH ID: 00C8006000160000 Flash Type: SF_GD25LQ32 Size:0x400000(4MB) >>The 1st boot failure,Please reduce Baud-rate and try again! 1843200 baud rate same set problem is cant register calls log |
07-23-2015, 12:12 | #4 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Quote:
