Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Volcano Box
Old 11-16-2013, 03:36   #1 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 331
konka T640s trying to format but give error(solved)
Hi Team i have konka i need to remove password i use volcano cable with o5b clip i get this error when i try to format the phone
 Detection initiated...
  Vcc: null
  Gnd: 5
  Analyzing D+ and D-...
  D+ = 3, D- = 2
  Analyzing USB device, please wait...
  Find USB device:SPRD U2S Diag (COM65), (VID_1782&PID_4D00)
  Internal version: SPRD3
  Boot downloaded.
  Start boot please wait a moment....
  Spreadtrum Boot Block version 1.1
  Boot downloaded.
  The 2nd boot failure
>>Start analysis mobile data...
can not do phone unlock
can not do imei repair
what to do?
Old 11-16-2013, 07:19   #2 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,358
update drivers and install these drivers please
spd sci-android-usb-driver-jungo-v4 - Download - 4shared
Old 11-18-2013, 02:12   #3 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 331
still same when i try to format showing this
  Vcc: null
  Gnd: 5
  D+ = 3, D- = 2
  Detection D+/D- with 0.92 seconds.
  Continue to detect BOOT pin...
  Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
  UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4
  Setting...
  Pinouts setting complete!
  Boot downloaded.
i can read flash file i can read info but can not do anything ales
what to do?
Old 11-19-2013, 07:39   #4 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 331
where is the support plz reply what to do?
Old 11-20-2013, 21:58   #5 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 331
i have 2 phone now same problem restart plz tell me how do i format why i can not format?
Old 11-20-2013, 23:23   #6 (permalink)
soshan's Avatar
Member: 592636
Thanks Meter: 651
only chengh comport and use spicial usb cable from phone package , many times if uu chengh comport ,solve this problem , if u have same problem u should bulding magic cable and solve ur problem.
Old 11-21-2013, 06:18   #7 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,358
its 100% drivers problem , update spd drivers
Old 11-21-2013, 06:33   #8 (permalink)
..::One-Man::..'s Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,522
@...MUTUAL
Its For 2 Problem . 1ST For Driver 2nd For Wrong Boot
Did You Update Driver & Select Correct Boot ? (Boot 14)
Also Downgrade Your Phone Port In 15
Br.
Azimbahar
Old 11-21-2013, 07:43   #9 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 331
Originally Posted by ..::One-Man::.. View Post
@...MUTUAL
Br.
Azimbahar
salam n thanks for the reply the link u gave me i already update to that driver
i also downgrade port to 15 here is the pic
always this error when i try to format i got 2 same phone now both restart problem
i click the spd port witch was at 65 then press update driver i located the driver to folder the one u told me to download
after install i change port to 15
i did all this no luck
plz correct me if i m wrong
Old 11-22-2013, 06:03   #10 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 331
plz help me out if 100% driver problem tell me what i m doing wrong?
i need to shorted out give to my customer
if u want i can show u on team viewer
thanks
Old 11-22-2013, 07:03   #11 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 331
@...MUTUAL
Br.
Azimbahar
with usb cable with boot key u can see it can connect on device manager but can not connect with volcano so now what is the wrong?
i m doing right ? software have bug?
what to do?
Old 11-22-2013, 21:12   #12 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,358
connect phone
first select port 15 then press run button
and post result
Old 11-23-2013, 05:11   #13 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 331
connect phone
and post result
ok here u go first connect the phone then select manually comport 15
after the unlock auto detect pin out
then pres run nothing happened only saying plzz power on the phone.
u can see phone is connect with com 15
what to do?
this is with usb cable
with volcano i can connect but can not format
i really need some one who can check it out why can not connect with usb
thanks
Old 11-23-2013, 05:28   #14 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,358
Connect with me on yahoo or sonork , I try to help you
Old 11-25-2013, 05:44   #15 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 331
hi i m online and i already left message on yahoo can u plz come online and check what is wrong on it?
Page generated in 0.51359 seconds with 7 queries
