Lava C31 how to format Lava C31 how to format the condition of set is ok but need to reset security lock screenshot http://i49.tinypic.com/vice1y.jpg |
hi i think its MSTAR cpu.... n ur prblem is securty code read flash file then u can check user code..... ... test n post results... |
its not detecting as com port.......its detecting as mass storage and as the set is new and under warranty i dont want to open the set for rx tx..... |
@buntymurarka Its MTK Phone If Key pad Phone then Hold 2+5 . If Touch Screen then Press hold Volume down key, Volume up key , Home button, home button + Volume up key. home button + Volume down key Send key, Try again & Post Result |
no volume keys on the set........ |
done by pressing call key+home key+end key........now com port is detected... screenshot http://i49.tinypic.com/20gkupi.jpg |
happy to See Ur Problem Solved. Enjoy Volcano Box |
Lava C31 & C51 USB Flashing By Volcano Box I successfully flash LAVA C31 & Lava C51 Mobile by usb flashing by Volcano Box I haven't Screen Shots but this is 100% Tested solution by me you can test it & post the results. 1. Select flash file 2. untick Auto-detect Pinout 3. Select Usb Mode 4. select write flash & run 5. insert battery on phone, hold call button & insert usb cable, you can see the progress bar going on & flashing done. 6. Now write phone imei nos. Thanks for volcano team.......... |
Lava C51 USB Flashing By Volcano Box Lava C51 USB Flashing By Volcano Box http://i49.tinypic.com/2usbrr9.jpg http://i50.tinypic.com/r8ftxt.jpg http://i48.tinypic.com/1z732ms.jpg Flashing Process :- 1. Select flash file 2. untick Auto-detect Pinout 3. Select Usb Mode 4. select write flash & run 5. insert battery on phone, hold call button & insert usb cable, you can see the progress bar going on & flashing done. 6. Now write phone imei nos. Thanks for volcano team.......... |
