11-01-2015, 11:05 | #4 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | try to read flash and write flash ? Br Faisal_Computer |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
04-06-2016, 17:41 | #7 (permalink) |
Freak Poster Join Date: Jun 2012 Location: india
Member: 1773058 Status: Offline Thanks Meter: 64 | I alrady use merapi tool 1.4.7 but all tab/funtions are not work . Only show 'server...ok' then stop. (not work-factory tool, multi brand, datd pro, flash tool, And mtk, cdma tool, sam tool) also i format my pc. And adding merapi folder Exclusion in Antivirus. But problem same. How to recover my problem ? Last edited by Suja786; 04-06-2016 at 17:48. |
04-06-2016, 17:57 | #8 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2463805 Status: Offline Thanks Meter: 32 | Use full version of merapi & add exclusion Download and use full version of merapi for full access If antivirus blocked merapi add exclusion or disable antivirus when you using merapi but if you unzip merapi the antivirus may detect as a virus so disable antivirus first Then add as the merapi.exe in exclusion settings on your antivirus . Then it will be perfectly work |
The Following User Says Thank You to pirunthan7 For This Useful Post: |
04-06-2016, 20:14 | #9 (permalink) | |
Member: 1773058 Status: Offline Thanks Meter: 64 | Quote:
first read my post. alrady i do it. also remove antivirus from my pc. but result same. | |
04-06-2016, 20:20 | #10 (permalink) |
Freak Poster Join Date: Apr 2014 Location: Mostly on Skype :)
Member: 2161887 Status: Offline Sonork: 100.1605383 Thanks Meter: 193 | Suja contact me on skype , i ll help you to sort out this problem |
The Following User Says Thank You to mrgsm123 For This Useful Post: |
