Micromax a30 patternlock how to unlock Micromax a30 patternlock how to unlock hardreset not working volume key on recovery mode not working so cant rset or wipe pls help |
Press and hold vol (-) and vol (+) and power button wait for android logo after you see android logo press home button you can see recovery mode press vol down button select factory reset and reboot |
any solution ? |
Dear Friends Micromax A30 Done With This Method. Press And Hold Volume + Then Power On. It'll Come At Android Logo. Then Press Home Button. Then Select Wipe Data/factory reset By Volume Down Key. Then Select By Back Key (Left Of Home Key) Then Select Yes--delete all user By Back Key (Left Of Home Key) Hard Reset Done!!! |
i also tried that but failed then i flashed the software and its done Sent from my iPhone using Tapatalk |
#8 is correct method |
i have a problem to do hard reset for micromax a30 with this method Quote:
a30 micromaxx hard not done volume key not working in recovery mode.reached that area but volume up and down not working flash set orignal flash tools then set ok enjoy :) |
i ill try this lots of time can,t work |
