01-30-2014, 08:21 | #4 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,975 | Its SPD android If phone have fastboot mode or debag enable do wipe Or do format At last solution flash : http://support.moulnisky.com Br AzimBahar |
06-26-2014, 10:06 | #5 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Earth
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Easy solution A61 Pattern Unlock Done By a Small Trick *First Press Power Button (I) *Then Immediately Press Volume Down- (Keep Pressing Vol Down Till you get Recovery Mode) *In Recovery Press Volume Up+ To Get Recovery Options That's All ! Press Thanks If success |
07-15-2014, 08:35 | #6 (permalink) |
Junior Member Join Date: May 2011
Member: 1574070 Status: Offline Thanks Meter: 3 | Brother.....press power key of your a61....after showing BOLT logo press volume (-) key immidiately together....press them for 15 seconds then remove your finger from the keys......it wil show BOLT again and then it wil go to boot manu..... select wipe/cache data by downkey(-) key and press power key..... the set will restart automatically and your problem will be solved........thanks...... |
The Following 3 Users Say Thank You to gopalkanu For This Useful Post: |
09-29-2014, 11:46 | #8 (permalink) | |
Registered User Join Date: Dec 2007 Location: krishnagiri
Member: 645764 Status: Offline Thanks Meter: 208 | Quote:
