Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Volcano Box
Old 10-05-2013, 09:55   #1 (permalink)
NokiaMobileCare's Avatar
Member: 652870
Thanks Meter: 135
Micromax A67 Pattern Lock Solution Tested . Feel the power of Volcano
Finally tested solution with Volcano
1st go to MTK Tab select default Built-in Boot _ Auto
2nd click on one key root
3rd untick Auto Detect Pinout
4th select usb mode .
5th select ADB_Root
6th power on ur phone after on screen u will see enter gmail id & pass
Click on Run
connect your phone with pc ...
after that u see connecttion phone
phone connection is successfull
Root process may restart the phone several times, keep your phone and data lines connected correctly.
Getting Root privileges, please wait...
Phone Model: Micromax A67
Android Release: 4.0.3
wait for the full process it may takes maximum 5 to 7 mins just wait aftr root success phone is reboot thn again
after root just change the option
now select Reset_Gmail
here is snapshot
Volcano world's No 1 Box in GSM History
Great works from Volcano Team ....
The Following 10 Users Say Thank You to NokiaMobileCare For This Useful Post:
Old 10-05-2013, 10:12   #2 (permalink)
Moiz Khan's Avatar
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,011
5th select ADB_Root
Click on Run
I think this is only possible if by luck phone has "USB Debugging ON" ...OTHERWISE..!
The Following 2 Users Say Thank You to Moiz Khan For This Useful Post:
Old 10-06-2013, 13:41   #3 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 369
Already Micromax A67 Pattern Lock Unlock By Me
I Do Already Micromax A67 Pattern Unlock In VOLCANO BOX Without Loss Any Data
See This Link
http://forum.gsmhosting.com/vbb/f723...o-box-1719605/
The Following User Says Thank You to Yashbanswara For This Useful Post:
Old 10-10-2013, 19:17   #4 (permalink)
Member: 1620176
A67 micromax
dear how to use cable for a67 formate by volcano box its urgent
Old 10-10-2013, 20:29   #5 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,361
for above method you can use normal usb cable
Old 10-15-2013, 19:32   #6 (permalink)
barabanki gsm's Avatar
Member: 1698801
Thanks Meter: 29
What happen if usb debbuging is not on .is this trick work
Sent from my GT-I9070 using ******** 2
Old 10-18-2013, 06:49   #7 (permalink)
Member: 1874281
>>Unable to connect to the device, make sure the data cable is connected to the phone, USB Debugging is already open.
i m getting error plz tell me what to do now ?
Old 10-18-2013, 06:58   #8 (permalink)
Moiz Khan's Avatar
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,011
Lightbulb
for your problem see this reply :
Old 10-18-2013, 13:58   #9 (permalink)
Member: 1874281
moiz bhai i try this method step by step but getting error
Old 10-18-2013, 14:05   #10 (permalink)
Moiz Khan's Avatar
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,011
Lightbulb
this procedure will only work if USB DEBUGGING is already ON in the handset by the user...and if its OFF then this method wont work..!
Old 10-18-2013, 15:46   #11 (permalink)
Member: 1642979
Sonork: 100.1613407
Thanks Meter: 179
yes this is right not working when usb debug off
Old 10-19-2013, 09:28   #12 (permalink)
Member: 1874281
thanks for rplying moiz bhai but agar usb debugging mode of hai toh how to solve a67 patternlock ? is there any other solution for a67 patternlock ?
Old 10-19-2013, 09:48   #13 (permalink)
Moiz Khan's Avatar
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,011
Arrow >>>
If "USB Debugging is OFF" in Micromax A67
Then This is the Only Solution :
See this Video : Micromax a67 Pattern/Google Lock Remove Done By OG Flasher And And File - YouTube
For Flasher & Flash File, Go to this post >>
[Firmwares collection] Micromax Android- All Flash File Only Here [Mega Thread]
bR. Smk
Old 10-28-2013, 09:46   #14 (permalink)
Member: 776165
Thanks Meter: 12
Old 10-30-2013, 12:34   #15 (permalink)
Member: 544326
thanks for great solution my micromax A67 successfully done by given solution
But this solution work in voceno tool 2.3.2 only other version of voceno tool cant work for this
for download volceno tool 2.3.2
VolcanoTool_v2.3.2
Page generated in 0.40425 seconds with 7 queries
