Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 08-26-2013, 20:15   #1 (permalink)
SAYAN_KULTI's Avatar
Member: 1338657
Sonork: 100.1620835
Thanks Meter: 159
micromax a72 canvas pattern lock solution
1, OPEN VOLCANO
2,SELECT MTK CPU, CLIK RUN
3, DONT USE BOX POWER CABLE, USE BATTERY
4, SEE THE MOBILE LCD, SHOW ANDROID LOGO
5,CLIK HOME
SELECT, WIPE DATA FACTORY RESET
SELECT YES_DELETE ALL USER DATA
DONT FORGATE THANKS BATTAN
BR, SAYAN
Old 08-27-2013, 03:09   #2 (permalink)
Mirtelecom's Avatar
Member: 1754881
Sonork: 100.1644926
Thanks Meter: 146
Good solution but i try it through formate and volcano 100% solve it.
Thanks
The Following User Says Thank You to Mirtelecom For This Useful Post:
Old 08-27-2013, 05:53   #3 (permalink)
sunil1670's Avatar
Member: 1849215
Thanks Meter: 136
already done more then 20 handsets , good but old solution bro
Old 08-27-2013, 09:33   #4 (permalink)
.::PankajMobileWorld::.'s Avatar
Member: 1910515
Thanks Meter: 289
check your report..........
check boot file..............
USB Cable use it........
see this Link........already post it.
http://forum.gsmhosting.com/vbb/f723...o-box-1683013/
Old 10-18-2013, 10:33   #5 (permalink)
Member: 1115725
Sonork: 100.1653957
micromax A72 patternlock Done by GPG Dragon
I have use the above instruction and done the pattern lock with gpg drgon thanks ......bro
Old 10-20-2013, 07:13   #6 (permalink)
Member: 582476
Thanks Meter: 8
i do flashing to remove pattern lock in a72, but now a72 came with sw ver m002, for this handset if i flash with ver m001, handsets imei get 00000, ver m002 flash file are not available, then i try instruction give above with almost 6 handset, i don't get that android logo, i try some other trick in forum but still i don't successes with this, so i can't understand what i get wrong.
Old 10-22-2013, 05:33   #7 (permalink)
jkniji's Avatar
Member: 643992
Sonork: 100.1625367
Thanks Meter: 180
here is step by step with image write imei no. writing solustion write comments is useful
..............wbr .........jkniji
http://forum.gsmhosting.com/vbb/f723...ccess-1727550/
Old 11-14-2013, 06:03   #8 (permalink)
Member: 2048307
Sonork: ROHIT KUMAR
i need help to remove the pattern lock of micromax A72 by gpg dargon now plzz
Old 11-14-2013, 08:05   #9 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
very old what,s new???
The Following User Says Thank You to ARIF GIGANI For This Useful Post:
Old 11-14-2013, 12:38   #10 (permalink)
Crazy Poster
Member: 1756270
Sonork: 100.1655433
Thanks Meter: 3
not success bro plz help
Old 11-22-2013, 06:32   #11 (permalink)
maqsod's Avatar
Member: 666362
Thanks Meter: 134
easy way to unlock thanks brd 1000% success full working
Old 02-19-2015, 09:54   #12 (permalink)
Hatimhunk5's Avatar
Member: 2117717
Sonork: 100.1663585
Thanks Meter: 28
Fine and Old Solution working 1000000%...keep it up
Page generated in 0.18820 seconds with 9 queries
