11-16-2013, 03:36 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | konka T640s trying to format but give error(solved) Code: Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Analyzing USB device, please wait... Find USB device:SPRD U2S Diag (COM65), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. The 2nd boot failure >>Start analysis mobile data... can not do imei repair what to do? |
11-16-2013, 07:19 | #2 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | update drivers and install these drivers please spd sci-android-usb-driver-jungo-v4 - Download - 4shared |
11-18-2013, 02:12 | #3 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
Code: Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 0.92 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Setting... Find USB device:SPRD U2S Diag (COM65), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... >>Spreadtrum Boot Block version 1.1 what to do? | |
11-20-2013, 21:58 | #5 (permalink) | |
11-20-2013, 23:23 | #6 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iran-shushtar
Member: 592636 Status: Offline Thanks Meter: 674 | only chengh comport and use spicial usb cable from phone package , many times if uu chengh comport ,solve this problem , if u have same problem u should bulding magic cable and solve ur problem. |
11-21-2013, 06:33 | #8 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | @...MUTUAL Its For 2 Problem . 1ST For Driver 2nd For Wrong Boot Did You Update Driver & Select Correct Boot ? (Boot 14) Also Downgrade Your Phone Port In 15 Br. Azimbahar |
11-21-2013, 07:43 | #9 (permalink) | |
i also downgrade port to 15 here is the pic always this error when i try to format i got 2 same phone now both restart problem i click the spd port witch was at 65 then press update driver i located the driver to folder the one u told me to download after install i change port to 15 i did all this no luck plz correct me if i m wrong | |
11-22-2013, 07:03 | #11 (permalink) | |
i m doing right ? software have bug? what to do? | |
11-23-2013, 05:11 | #13 (permalink) | |
after the unlock auto detect pin out then pres run nothing happened only saying plzz power on the phone. u can see phone is connect with com 15 what to do? this is with usb cable with volcano i can connect but can not format i really need some one who can check it out why can not connect with usb thanks | |
