02-27-2013, 14:22 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 659890 Status: Offline Thanks Meter: 263 | micromax funbook pattern lock |
02-27-2013, 14:28 | #3 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | press vol+ and power on release buttons after recovery mode appears select wipe data (use vol up and down keys) press power button (for select action ) |
02-27-2013, 14:35 | #5 (permalink) |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | try with volcano go to detect tab select cpu auto detect if pinfind sucess the do it with volcano alter net solution then use adb commandline ... open cmd switch to folder"where is adb.exe"stand using cd <path> then "adb.exe" adb devices adb shell if you get # on cmd then "wipe data" exit adb reboot |
02-27-2013, 14:38 | #6 (permalink) | |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | Quote:
2:Press Volume up button, Menu button and Power on button at same time and hold up for 10 secs. Your phone will start and a screen appears with the android sign and after some time few options 3:Use your volume button for scrolling. 4:Select factory reset option using the power button.It will reset your tab. 5:Now select reboot option or restart your tab. Note: Factory reset will erase all data except on the SD card. br, azam | |
02-27-2013, 14:39 | #7 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gujarat, india
Member: 890965 Status: Offline Sonork: 100.1605360 Thanks Meter: 180 | prees vol.+and powar on prees back key and powar on prees vol.down and power on prees vol+reset key press vol+vol.down and power on post risalt you tab is find ricovery mode or not??? most worked is prees vol.+ and vol down and power on |
02-27-2013, 15:07 | #9 (permalink) | |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | Quote:
