01-19-2019, 14:30 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | micromax q370 frp problem Available Ports:COM1 COM2 COM139 15:38:29 Current Port:Com0 15:41:17 Current Task: Format>>SC7730/31 EMMC 15:41:18 Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 60 seconds. 15:41:18 Analysis of USB port,Please insert phone USB cable. 15:41:31 Phone found[SPRD U2S Diag (COM158)] 15:41:31 Internal version: SPRD3 15:41:31 Boot downloading... 15:41:35 INFERNO SPRD 773x bootloader v1.0 15:41:35 Boot downloading... 15:41:38 Factory reseting... 15:41:41 Format success. 15:41:44 Clear FRP Success 15:41:44 Wait until the phone boot up. also tried with fastboot mode: .Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. 13:47:44 Port Found[COM95]. 13:47:44 Hardware Id:0008c0e1 13:47:44 Inner boots do not match the phone,please select boot manually. 15:49:41 Ver:1.6.2 15:49:41 Current Task: Tools>>ADB Fastboot RsTools 15:50:03 All SPD FRP Unlock by FastBoot... 15:50:03 If stuck here more than 1 minute,check phone connect to computer in right mode 15:50:04 All SPD FRP Unlock by FastBoot Success showing success but still locked, please help? |
01-20-2019, 09:38 | #3 (permalink) |
No Life Poster Join Date: Apr 2013 Location: india
Member: 1911060 Status: Offline Sonork: [email protected] Thanks Meter: 303 | connect with wifi some mobile need wifi after reset frp |
01-20-2019, 13:12 | #5 (permalink) |
Member: 1911060 Status: Offline Sonork: [email protected] Thanks Meter: 303 | connect mobile in fastboot mode open inferno universal tool open tool tab open adb and fastboot rs tool select All SPD FRP Unlock by FastBoot.. and do your job |
01-21-2019, 05:32 | #7 (permalink) |
Member: 1911060 Status: Offline Sonork: [email protected] Thanks Meter: 303 | not possible bro in inferno i was 100% done this phone many times |
01-21-2019, 05:32 | #8 (permalink) |
Member: 1911060 Status: Offline Sonork: [email protected] Thanks Meter: 303 | |
01-21-2019, 18:19 | #9 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Yes... Same here... I have also done this before in the same model successfully, but don't know why in this phone I am not able to unlock with the same procedure I did before, is it emmc problem, please suggest? |
