04-20-2014, 21:44 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Tabligbo
Member: 1032123 Status: Offline Sonork: akeal81 Thanks Meter: 29 | Mstar mw8533d not read |
04-21-2014, 14:47 | #5 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,257 | @ akeal81 .... Use Modify Cable .. http://forum.gsmhosting.com/vbb/9347474-post1.html If you Use this Cable for Mstar Chip .. No Need Any Power or Buttery .. Just Plug the Cable .. Or You Can use Also Volcano Main Cable .. First Connect the Jig Correctly & Install Mstar Driver Properly .. Use Default Boot No need to change Baud rate .. Select Read/Write & Do Run .. If you Get Any Error ... Use Volcano low Version & Post Result ... Br, AniAXN Last edited by AniAxn; 04-21-2014 at 14:55. |
The Following User Says Thank You to AniAxn For This Useful Post: |
