06-02-2015, 19:03 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Jammu & Kashmir (India)
Member: 367928 Status: Offline Thanks Meter: 178 | MT 625a read write always fail [Solved] read flesh write flesh always fail plz help Waiting for phone's response,please press Power on/off button Failed to open port. IF Software stop here. you see Stop(red) button become Run(Green) please press and hold power button till boot downloading not start, then release power button, when you releaes power button if boot downloading stop this mean you have HARDWARE fault in your mobile Waiting for phone's response,please press Power on/off button. Failed to open port. IF Software stop here. you see Stop(red) button become Run(Green) please press and hold power button till boot downloading not start, then release power button, when you releaes power button if boot downloading stop this mean you have HARDWARE fault in your mobile Available Ports:COM1 COM4 Available Ports:COM1 COM4 Available Ports:COM1 COM4 Available Ports:COM1 COM4 COM20 Waiting for phone's response,press the Power on the phone. Fail to connect. Error 494883356 Mobile Information: Baseband chip Version:MT6261 DSP Firmware Version:2000.00.00 DSP Patch Version:1.0 Software Version:LAVA_KKT_Alpha_S112_20141202 Hardware Version:VSUN61M_11C_HW Audio Version:Unknown CPUID:00000000 IMEI1:000091142135137 IMEI2:000091142135137 Waiting for phone's response,press the Power on the phone... Fail to connect. Error 475201084 Available Ports:COM1 COM4 COM20 Waiting for phone's response,press the Power on the phone Waiting for phone's response,please press Power on/off button. Failed to open port. IF Software stop here. you see Stop(red) button become Run(Green) please press and hold power button till boot downloading not start, then release power button, when you releaes power button if boot downloading stop this mean you have HARDWARE fault in your mobile Waiting for phone's response,please press Power on/off button. Failed to open port. >>IF Software stop here. you see Stop(red) button become Run(Green) please press and hold power button till boot downloading not start, then release power button, when you releaes power button if boot downloading stop this mean you have HARDWARE fault in your mobile even after detection via usb or jig get info, read write flesh format all fail |
06-03-2015, 04:59 | #2 (permalink) | |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
We Cannot Recognize Your Problem .. !! Your Phone Not Detecting With Volcano Or Not Read Flash Or Format Phone ?? Use Volcano 3.0 And Post Results With Screenshot .... | |
06-03-2015, 06:20 | #4 (permalink) | |
Member: 367928 Status: Offline Thanks Meter: 178 | Quote:
i already try sir but reading flesh always fail with usb and with jig also see my first post as i mentioned that in unlock code it read info with jig nut only info with imei not security code and reading flesh or info or formet all fail with three diffrent phone i have, may be driver problme or what ? | |
06-03-2015, 06:26 | #5 (permalink) | |
Try 3.0 and Post Results ... | |
06-03-2015, 06:42 | #6 (permalink) | |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Quote:
Run Volcano 3.0.0 Version .. Go to MTK tab & Select Boot 11 .. Do JOB with USB Mode .. Note - 3.0.2 version have some mtk bugs so use 3.0.0 version WBr, AniAXN | |
06-03-2015, 07:01 | #7 (permalink) | |
yes sir thanks a lot, it was bug of 3.2, i do it with 2.96 i try with old ver last night but now it work with 2.96 thanks for help | |
