07-14-2013, 20:49 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 778346 Status: Offline Thanks Meter: 34 | mt6575 android imei remain same after change pls help ================================== Some preparations for operation 1.Insert phone SIM card 2.Power on phone please 3.Turn off flight mode 4.Phone USB mode is enabled ================================== Connecting, Please Wait... Found Device...0123456789ABCDEF Model = GT-I908 OS Version= 2.3.6 CPU TYPE = mt6575 CPU TYPE 2= MT6575 Model= ALPS.GB2.MP.V2.21 Device Info 1= MAUI.11AMD.W11.50.SP.V30.P2, 2013/04/23 16:21 Display ID= lcsh75cu_gb2 SIM CARD IS READY... IMEI 1= 359447747777444 IMEI 2= 359558899889088 Running data do not touch phone... Please Switch off device and switch on again?? Waiting for device to connect... Rechecking Imei Found Device...0123456789ABCDEF IMEI 1= 359447747777444 IMEI 2= 359558899889088 Write IMEI done, reboot please. 65xx new method 1.Select the mobile's USB debugging. 2.Please input 15 bits of IMEI and click button Write IMEI. 3.When software shows Searching port,please power off mobile phone with battery inside and connect to box with cable. COM port searching and preloader handshake. Connect port COM13. COM port searching and preloader handshake. Connect successfully. CPU TYPE:MT6575 DSP Firmware Version: DSP Patch Version: Software Version:MAUI.11AMD.W11.50.SP.V30.P2 Hardware Version:LCSH15CU_HW Audio Version:Unknown IMEI1:359447747777444 IMEI2:359558899889088 IMEI success. >>Write IMEI done. |
07-15-2013, 09:31 | #5 (permalink) |
Member: 778346 Status: Offline Thanks Meter: 34 | problem not solved pls help model samsung GT-I9082 Grand Copy 3pcs same problem read info log Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:6575 Hardware version:CB00 Software version:E201 Boot downloading complete! Flash ID: 009800BC Flash Type: NAND_TYBC0A111236KC10 >>Chip Capacity: 0x20000000(512MB) image ru |
07-16-2013, 10:49 | #7 (permalink) |
No Life Poster Join Date: Aug 2012 Location: India Age: 39
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | first root with volacno tick one key root untick auto detact pinout tick usb mode run press boot key then insert usb cable show save option enter name press save after 30sec your phone rooted then try again write imei with new method |
07-19-2013, 16:45 | #14 (permalink) |
Banned Join Date: May 2012 Location: in ur heart Age: 32
Member: 1761678 Status: Offline Sonork: 100.1615439 Thanks Meter: 370 | do u do this first root with volacno tick one key root untick auto detact pinout tick usb mode run press boot key then insert usb cable show save option enter name press save after 30sec your phone rooted then try again write imei with new method |
07-19-2013, 17:48 | #15 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: GSM-WORD
Member: 240763 Status: Offline Sonork: 100.110277 Thanks Meter: 105 | Quote:
