01-29-2014, 02:02 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Location: burkina faso Age: 51
Member: 70259 Status: Offline Thanks Meter: 53 | Mt6575 format ok but not done i need help to reset gmail in my samsung copy i8190 mt6575.debug mode not actived then when i try to format with all option operation ready but gmail steel not remove.anyone can help me? Thanks |
01-29-2014, 04:21 | #3 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Because your phone formatting On Address 00000000 Now you can try auto format using android tools If same you can do try with another version If same you need Do Customize / manual format Or Do wipe On meta mode http://forum.gsmhosting.com/vbb/f723...lcano-1756187/ Br AzimBahar |
The Following User Says Thank You to aZimBahar For This Useful Post: |
01-30-2014, 08:59 | #4 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2116561 Status: Offline Thanks Meter: 1 | temporary ADB without usb debugging is not working in MT6575 cpd i'll try to format my phone with the address 0x00000000 length 0x20000000 but my phone is dead after format i have back up almost 512mb but when i write it back it cant write the run button it appear stop then after reading info it returns to RUN here is the log Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:6575 Hardware version:CB00 Software version:E201 Boot downloading complete! FlashID:002C00BC00900066 Flash Type: NAND_MT29C4G48MAZAPAKD FlashLen:20000000 >> hope volcano can solve this problem |
01-30-2014, 09:03 | #5 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Its working , many & more time tested Why you Do format to wrong address ? Now to write flash using boot 13 also with 14 Br AzimBahar |
01-30-2014, 09:37 | #6 (permalink) |
Member: 2116561 Status: Offline Thanks Meter: 1 | ive tried sir but still the same Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:6575 Hardware version:CB00 Software version:E201 Boot downloading complete! FlashID:002C00BC00900066 Flash Type: NAND_MT29C4G48MAZAPAKD FlashLen:20000000 Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:6575 Hardware version:CB00 Software version:E201 Boot downloading complete! FlashID:002C00BC00900066 Flash Type: NAND_MT29C4G48MAZAPAKD FlashLen:20000000 |
02-01-2014, 13:38 | #10 (permalink) | |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Quote:
If you can not activate meta adb , So try it : http://forum.gsmhosting.com/vbb/f781...-azim-1761721/ Also you can solve user data file , if you have Factory backup If same Do Customize format , Make a sure your adress & len Is right Br AzimBahar | |
02-02-2014, 00:45 | #11 (permalink) | ||
Member: 2116561 Status: Offline Thanks Meter: 1 | Quote:
Now i try to put the address as i posted above and now the phone is dead. I have readed back up almost 512mb but my problem is i cant write it back If you can help me to analyze i can upload and i can send to you Waiting for your reply | ||
02-02-2014, 04:14 | #12 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | If same Do Customize format , Make a sure your adress & len Is right What is this mean ? Why you entry wrong ? If you dont know Why not search ? Or Why now Question Us ? If is dead , So you need Flash . On flashing what error ? Post Screenshots Br AzimBahar |
