04-30-2014, 07:40 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | MTK USB METHOD.. port dissapear quickly need help |
04-30-2014, 07:42 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Power on mobile and insert normal usb cable.. it would ask usbmass or comport.. Select com port now check port number in device manger and click write imei option in volcano select port and write it.. restart mobile and you are done.. |
04-30-2014, 10:01 | #7 (permalink) | |
Member: 1507693 Status: Offline Thanks Meter: 131 | Quote:
i found the boot key, and i can read flash, but i cant write imei, i select mtk port on imei options and software says press power on yet im using usb cable with boot key if i select USB under options it shows imei written but on phone is still invalid imei | |
04-30-2014, 10:31 | #8 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Quote:
after insert usb cable when software change auto com port then click on imei tool and press run BR Qaisar Mahmood | |
