03-03-2015, 22:38 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Venezuela
Member: 1788767 Status: Offline Sonork: walidjamil Thanks Meter: 28 | MTK6571 read and save flash ok but cant write flash Available Ports:COM7 COM17 COM41 COM99 COM100 Current Port:COM41 Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:MT6571 Hardware version:CA00 Software version:0000 SecCfgVal :0x00000000 BromVersion :0xFF BLVersion :0x01 Boot downloading complete! FlashID:002C00BC00900066 Flash Type: NAND_MT29C4G48MAZAPAKD FlashLen:20000000 Analysis of USB port... Flash reading complete! >>Spend time 217.2 s |
03-03-2015, 22:39 | #2 (permalink) |
Member: 1788767 Status: Offline Sonork: walidjamil Thanks Meter: 28 | cant write flash Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:MT6571 Hardware version:CA00 Software version:0000 SecCfgVal :0x00000000 BromVersion :0xFF BLVersion :0x01 Boot downloading complete! FlashID:002C00BC00900066 Flash Type: NAND_MT29C4G48MAZAPAKD FlashLen:20000000 >>Analysis of USB port... |
03-03-2015, 22:41 | #3 (permalink) | |
Member: 1788767 Status: Offline Sonork: walidjamil Thanks Meter: 28 | Quote:
Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:MT6571 Hardware version:CA00 Software version:0000 Boot downloading complete! FlashID:002C00BC00900066 Flash Type: NAND_MT29C4G48MAZAPAKD FlashLen:20000000 >>Analysis of USB port... | |
03-04-2015, 04:37 | #4 (permalink) | |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
The Following User Says Thank You to zoneofash For This Useful Post: |
03-05-2015, 07:36 | #6 (permalink) |
Junior Member Join Date: Jul 2005 Location: Indonesia, Pemalang Age: 46
Member: 160217 Status: Offline Thanks Meter: 5 | same as me. the phone is advan s3+ flash read is okay in usb mode, cannot write back and i cannt get into adb mode , is there any trik i can do ? helppp |
03-05-2015, 07:49 | #7 (permalink) |
Member: 160217 Status: Offline Thanks Meter: 5 | mtk6571 cannot write flash this the screenshot, sorry i cannot also upload screenshot PIC_2015_03_05_1_45_16_PM.jpg: Upload of file failed. |
03-05-2015, 09:30 | #8 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Try In MTK Tab With Boot #15 And Post Result Here . |
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
03-06-2015, 05:46 | #12 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1005456 Status: Offline Thanks Meter: 39 | i think this is same problem on other Mt6571 device here in Ph.. when you try to flash the phone even it is completed on Volcano the result is stil dead set.. And when you try to flash on Sptool it stop on 4%.. But there is some Co-tech here in the Ph found the Solution to make it continue on Flashing in Sptool and dont stop in 4%.. Or even the flashing is completed still the phone is Dead.. In Sptool there is what so Called Advanced mode Setiings.. NOTE: NOt All Mt6571/mt6572 Chipset Support by Sptool on Format All + Download yuore device will Brick on this Method of Flashing.. Much better to use Donwload only or the Firmware Uprade settings this settings will not killl youre phone.. Here is the trick of Sptool Mt6571 to make it countiue again in flashing. Open Sptool and go to Format Tab and press on keyboard Ctrl Alt V and choose format whole flash and forecedly Erase (Bad blocks mark is erased) Go to options and choose Download and put check PhysicalFormat/readback And back to Download Click start rievax VIOLA.... Last edited by rievax; 03-06-2015 at 05:56. |
The Following 3 Users Say Thank You to rievax For This Useful Post: |
03-06-2015, 06:02 | #13 (permalink) |
Member: 1005456 Status: Offline Thanks Meter: 39 | i think this is same problem on other Mt6571 device.. when you try to flash the phone even it is completed on Volcano the result is stil dead set.. And when you try to flash on Sptool it stop on 4%.. But there is some Co-tech here in the Ph found the Soulution to make it continue on Flashing in Sptool and dont stop in 4%.. Or even the flashing is completed still the phone is Dead.. In Sptool there is what so Called Advanced mode Setiings.. NOTE All Mt6571/mt6572 Chipset doesnt Suuport by Sptool on Format All + Download yuore device will Brick on this Method of Flashing.. Much better to use Donwload only or the Firmware Uprade settings this settings will not killl youre phone.. Here is the trick of Sptool Mt6571 to make it countiue again in flashing. go to Download and press on keyboard ctrl + V and chose format whole flash and forecedly Erase (bad blocks mark is erased) Go to options and choose Download and put check PhysicalFormat/readback And back to Format Tab and Click start and after erasing flash youre phone and Set Sptool on Download only rievax VIOLA.... |
The Following 2 Users Say Thank You to rievax For This Useful Post: |
