01-22-2015, 08:57 | #4 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | First of All Check May be usb debug is on if on then Go to android tab then ADB & Wipe if off then try to put your mobile in recovery mood or Factory mood , if you can go in recovery then do wipe data in recovery menu , if you can go to Factory mood then root with Vroot after root Again in factory mood then wipe in Android > ADB tab>Wipe . |
01-22-2015, 09:19 | #5 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: in Heart of someone
Member: 1640158 Status: Offline Sonork: 100.1615555 Thanks Meter: 138 | Quote:
and thanks for the reply.. ?? | |
01-22-2015, 12:00 | #6 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | if usb debug is on then 1 > connect your mobile on usb cable 2 > install driver 3 > open Volcano software go to Android Tab then ADB tab 4 > root your mobile in adb tab 5 > wipe data in factory mood you can see option like this option can be different from picture if you have clear flash option then just clear flash & done you can get factory or recovery mood by below method Press and hold volume down then press power button Press & hold volume up then press power button Press & hold volume down & up together then press power button you can try by pressing all buttons with power button . |
