11-02-2016, 15:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Lahore Age: 38
Member: 1016490 Status: Offline Thanks Meter: 290 | Need help to activate inferno |
11-03-2016, 10:20 | #4 (permalink) |
Freak Poster Join Date: Oct 2016
Member: 2640240 Status: Offline Thanks Meter: 150 | hello how to registered your merapi tool ist time http://forum.gsmhosting.com/vbb/12137447-post5198.html here video step by step how to used inferno software http://forum.gsmhosting.com/vbb/12136394-post2.html |
11-03-2016, 12:04 | #5 (permalink) | |
Member: 1016490 Status: Offline Thanks Meter: 290 | Quote:
Disconnect with the volcano. The program is terminated. | |
11-03-2016, 12:10 | #6 (permalink) |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Brother you run worng exe. if you have volcano box then please run INFERNO VOLCANO MTK EXE IF YOU HAVE INFERNO DONGLE KEY THEN RUN INFERNO MTK EXE. HOPE YOUR UNDERSTAND NOW BROTHER. |
11-03-2016, 12:33 | #7 (permalink) | |
Disconnect the Volcanobox, The program is terminated. | |
11-03-2016, 12:41 | #8 (permalink) | |
Member: 2640240 Status: Offline Thanks Meter: 150 | Quote:
2-Box port is set on very high number Solution, 1-check the drivers so they are installed properly 2- Check the main switch of box is it presses inside..? So un-press switch outside 3-check the box port if its over the number of 20 than reduce the box port under 20 and set into any number Check all these and Run inferno tool,postcresult | |
The Following User Says Thank You to Lenoo For This Useful Post: |
11-03-2016, 12:56 | #9 (permalink) | |
