01-12-2016, 18:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: karoondi khairpur pakistan
Member: 669947 Status: Offline Sonork: 100.1614053 Thanks Meter: 157 | need help how remove pattern lock of qmobile t5 [ Answered ] |
01-12-2016, 18:44 | #2 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Pakistan Age: 26
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | Do Format With Merapi Tool or Try This Way [Tested] http:// www . all-gsm-solutions . tk /2015/12/qmobile-bolt-t5-hard-reset-only-here .html [Remove Spaces] |
01-12-2016, 20:32 | #3 (permalink) | |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,257 | Quote:
Hello, Install this driver SPD All Driver[32bits & 64bits]by AniAXN Wbr, AniAXN | |
The Following User Says Thank You to AniAxn For This Useful Post: |
01-13-2016, 10:32 | #6 (permalink) |
Member: 669947 Status: Offline Sonork: 100.1614053 Thanks Meter: 157 | 4:30:01 > Access to functional permissions from server...OK! >>Analysis of USB port,Please insert phone USB cable. 14:30:04 > 14:30:04 > Internal version: SPRD3 >>Boot downloaded. 14:30:05 > Start boot please wait a moment.... 14:30:07 > Spreadtrum Boot Block version 1.1 >>Boot downloaded. 14:30:08 > CPU TYPE:SC7715[7715A000] >>Boot downloaded. 14:30:08 > Flash ID: 00EC00BC006A 14:30:08 > Flash Type:[SAMSUNG] K9F4G08/K9K4G08 14:30:08 > FLASH LEN:0x20000000 14:30:08 > 14:30:08 > The phone is setting back to Factory... 14:30:43 > >>Formatting completed. but still same no unlock pattern yet |
01-14-2016, 05:30 | #8 (permalink) | |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
We Also Checking Our Side to If There an Issue | |
01-14-2016, 11:24 | #9 (permalink) |
Member: 669947 Status: Offline Sonork: 100.1614053 Thanks Meter: 157 | o k brother i try but same problem in merapi tool so please solve this in next update [QUOTEAfter Format Still Pattern Lock Remain Then Just Draw Any Pattern ..!! We Also Checking Our Side to If There an Issue][/QUOTE] |
01-14-2016, 12:11 | #11 (permalink) | |
Will Find Same Phone & Check it .. !! | |
01-14-2016, 13:11 | #12 (permalink) | |
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | Quote:
did u try adb method which i posted above ? | |
The Following User Says Thank You to masterRt1994 For This Useful Post: |
