12-27-2013, 22:09 | #1 (permalink) |
Junior Member Join Date: Jul 2007
Member: 550386 Status: Offline Thanks Meter: 3 | New white Volcano box pinouts problem After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Detecting rx and tx... Vcc: null Gnd: 5 Detection initiated, connect the phone and power on it... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... Failed to detect. For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: 5 Detection initiated... Failed to detect. For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: 5 Detection initiated... >>Failed to detect. |
12-28-2013, 00:46 | #2 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Brother hear I see gnd was directe ..Means pinfider is OK .. Try to System Recovery. ..if stall problem post result with screen shot. . Br, AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
12-28-2013, 18:58 | #4 (permalink) |
No Life Poster Join Date: Jan 2013 Location: India
Member: 1873645 Status: Offline Thanks Meter: 977 | bro....here is many reason for this problem. 1. may be charging/usb connector damage ? 2. this cpu is may be coolsand/ rda or spreadtrum. 3.may be boot key problem. for that solution 1. try to sold rx tx with mtk cpu mobile and check. 2. if you have working mobile then try to detect it. ............................. and if same then contect me on yahoo/sonork |
The Following User Says Thank You to laxmi kamlesh For This Useful Post: |
12-28-2013, 19:19 | #6 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | what chip inside phone ??? for many phone you need to keep press boot key ,like volum up or down key or menu key and also for may phone you need sod rx tx , so better also post phone details |
The Following User Says Thank You to sweet4hamza For This Useful Post: |
