03-28-2014, 14:18 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Octoplus Team
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | Nokia 108 cant flashing ???? please need advise The phone is dead after format. I tried firmware but not going on. Look logs please.......... Code: Volcano Updated: 2014-03-20 Connecting... Connection successful,connected state! Version: V3.8 SN:326-445-374 Port:COM3 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM1 COM3 COM13 COM14 COM15 COM16 COM17 COM18 COM19 Detection initiated, connect the phone and power on it... Vcc: null Gnd: 7 8 RX: 2, TX: 3 Connecting... Hardware version:CA01 Software version:0001 CPU TYPE:625A Internal version:8000 If it's a 625a phone, please select Boot V5.1232 manually and try again. IF Software stop here.you see Stop(red) button become Run(Green) please press and hold power button till boot downloading not start,then release power button,when you releaes power button if boot downloading stop this mean you have HARDWARE fault in your mobile Detection initiated, connect the phone and power on it... Vcc: null Gnd: 7 8 RX: 2, TX: 3 File versiBREE50D_PCB01_gsm_MT6250_S00.BREE_11_01_11_P1.bin Searching for passwords... Could not find any potential passwords. Connecting... Hardware version:CA01 Software version:0001 CPU TYPE:625A Internal version:8000 If it's a 625a phone, please select Boot V5.1232 manually and try again. IF Software stop here.you see Stop(red) button become Run(Green) please press and hold power button till boot downloading not start,then release power button,when you releaes power button if boot downloading stop this mean you have HARDWARE fault in your mobile Detection initiated, connect the phone and power on it... Vcc: null Gnd: 7 8 RX: 2, TX: 3 Connecting... Hardware version:CA01 Software version:0001 CPU TYPE:625A Internal version:8000 Boot downloading complete! Detection initiated, connect the phone and power on it... Vcc: null Gnd: 7 8 Waiting for phone's response,please press Power on/off button. Connecting... Hardware version:CA01 Software version:0001 CPU TYPE:625A Internal version:8000 >>Boot downloading complete! |
03-28-2014, 17:01 | #5 (permalink) |
No Life Poster Join Date: Apr 2008 Location: sweden
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | No brother Rx Tx not work for this phone error same like boot download complete so just use USB method 100% work for u I do daily 1or 2 set with out priblem |
03-29-2014, 05:51 | #6 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | I can not believe that phone is dead after format I do my self lot of phone but no one dead after format And with rx rx you can not format write flash or other things Bec not supported with rx tx yet Only USB can flash and format the phone Do by USB please |
The Following User Says Thank You to sweet4hamza For This Useful Post: |
03-29-2014, 07:36 | #7 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 706023 Status: Offline Sonork: 100.1647210 Thanks Meter: 75 | hello volcano has bug with write flash.try by dragon. http://forum.gsmhosting.com/vbb/f723...ackup-1792012/ |
04-10-2015, 08:07 | #10 (permalink) | |
Junior Member Join Date: Jan 2015 Location: Tegal, Indonesia
Member: 2337325 Status: Offline Thanks Meter: 1 | Can'tflash nokia 108 with usb Quote:
Connecting... Hardware version:CA01 Software version:0001 CPU TYPE:625A Internal version:8000 Analysis of USB port,Please insert phone USB cable. Connecting... Hardware version:CA01 Software version:0001 CPU TYPE:625A >>Internal version:8000 (Stoped here) | |
04-10-2015, 10:00 | #11 (permalink) | |
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
08-20-2017, 14:52 | #12 (permalink) | |
Insane Poster Join Date: Feb 2013 Location: Iran Age: 34
Member: 1878895 Status: Offline Thanks Meter: 19 | Quote:
Problem Sloved 1. solder usb cable to on board 2. coonect battery or + - power supply (3.7 V) to board 3. start format 4. connect usb cable to pc 100% test | |
