nokia x2-02 ..... i have nokia x2-02 after formatting no service or same time searching . before formatting set working slow .other phone working fine and after flash with phone backup same problem no service and searching plz help me about that problem http://www.shotpix.com/images/98464362737631906915.png |
not possible if u r fone is ok than why u formate it give us full detail |
and then i flash the the phone back set same condition no service and searching. |
2 Chang pa filter Ur problem 100 solved |
also faced same probelm tomarrow but luckily i had readed its full flash before format. so i wrote it back and phone worked and i returned it to customer with previous fault. (phone was hanging before format after format hanging problem was solved but phone gone to searcing mode. and when i write back readed flash file phone started hanging problem but signals were perfect.) |
your luck.. in my case it worked to retrieve phone to previous stage.... i think its a bug after formating phone goes to serching.. when you power on phone after formate check on display you will also see a error on phone like "rf value set to default"... am i right? |
br .::Mustafa::. |
BR. Arsalan gsm2000. |
bro its hardware problem change transmeeter ic |
after format or reset is software problem , it solved on writ by good working same id file , soon nv date read write option suported on volcano box then no need to flash the phone |
Thanks to all my problem is solved i back the phone same condition ............and return to customer. br .::Mustafa::. |
nokia x2-02 hang then software done but still hang problem pls help:confused::confused::confused: |
