01-28-2013, 07:42 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Khushab Punjab Pakistan
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | nokia x2-02 ..... before formatting set working slow .other phone working fine and after flash with phone backup same problem no service and searching plz help me about that problem |
01-28-2013, 08:03 | #3 (permalink) | |
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | Quote:
and then i flash the the phone back set same condition no service and searching. | |
01-28-2013, 08:09 | #4 (permalink) | |
Freak Poster Join Date: Nov 2012 Location: kwl pakistan
Member: 1842527 Status: Offline Thanks Meter: 40 | Quote:
2 Chang pa filter Ur problem 100 solved | |
01-28-2013, 08:23 | #6 (permalink) |
No Life Poster Join Date: May 2007 Location: .::Rawalpindi::.
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | also faced same probelm tomarrow but luckily i had readed its full flash before format. so i wrote it back and phone worked and i returned it to customer with previous fault. (phone was hanging before format after format hanging problem was solved but phone gone to searcing mode. and when i write back readed flash file phone started hanging problem but signals were perfect.) |
01-28-2013, 08:30 | #7 (permalink) | |
01-28-2013, 11:15 | #8 (permalink) |
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | your luck.. in my case it worked to retrieve phone to previous stage.... i think its a bug after formating phone goes to serching.. when you power on phone after formate check on display you will also see a error on phone like "rf value set to default"... am i right? |
01-28-2013, 12:31 | #9 (permalink) | |
br .::Mustafa::. | |
01-28-2013, 21:59 | #12 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | after format or reset is software problem , it solved on writ by good working same id file , soon nv date read write option suported on volcano box then no need to flash the phone |
01-29-2013, 08:51 | #13 (permalink) |
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | Thanks to all my problem is solved i back the phone same condition ............and return to customer. br .::Mustafa::. |
