Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Volcano Box
Old 01-07-2014, 12:23   #1 (permalink)
SHARMA NEERAJ's Avatar
Member: 419331
Thanks Meter: 92
Question note 3 copy write imei problam
i have a copy note3 i do write imei throw android tool show sussfull write imei but imei is same as is invlid see this log.( sim is inserted ) Connecting, Please Wait...
Found Device...0123456789ABCDEF
Model = SM-N9006
OS Version= 4.2.2
CPU TYPE = mt6572
CPU TYPE 2= MT6572
Model= ALPS.JB3.MP.V1
Device Info 1= MOLY.WR8.W1315.MD.WG.MP.V1.P2, 2013/10/24 16:17
Display ID= lcsh72_we_jb3
SIM NOT INSERTED PLEASE INSERT SIM FIRST. false
IMEI 1= 866837272772566
IMEI 2= 868576060282772
Running data do not touch phone...
Please Switch off device and switch on again??
Waiting for device to connect...
Rechecking Imei
Write IMEI done, reboot please.
plz hhelp what is problam
Old 01-07-2014, 12:40   #2 (permalink)
LuisinhoCell's Avatar
Member: 264903
Sonork: 1584531
Thanks Meter: 3,195
Use New Method
MTK 65xx New Method for imei repair
how to repair imei ?
go to MTK TAB
do Enable imei
click on Android tool
click on Run
click on MTK 65xx New Method
Fill imei in boxes
click on Write imei
when software saying searching for port
Insert Usb cable to phone in powered OFF condition !!
waiting software for process complete
after 2 secs your imei repair
[/SIZE]
LuisinhoCell
Old 01-07-2014, 12:50   #3 (permalink)
..::One-Man::..'s Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,499
Kindly try with Android tools Using volcano 2.4.3 & 2.4.5
Also Try New Mahmoud Using 2.4.5
Post result
AzimBahar
Old 01-07-2014, 15:19   #4 (permalink)
Member: 419331
Thanks Meter: 92
Question
Originally Posted by LuisinhoCell View Post
Use New Method
LuisinhoCell
no solution see this Some preparations for operation
1.Insert phone SIM card
2.Power on phone please
3.Turn off flight mode
4.Phone USB mode is enabled
1.Select the mobile's USB debugging.
2.Please input 15 bits of IMEI and click button Write IMEI.
3.When software shows Searching port,please power off mobile phone with battery inside and connect to box with cable.
Input IMEI2 less 15 bit.
COM port searching and preloader handshake.
Connect port COM75.
>>Write IMEI failed.
Old 01-08-2014, 09:22   #5 (permalink)
Member: 419331
Thanks Meter: 92
my phone and.ver. 4.3 imei write posibal or not tell volcano team
Old 01-08-2014, 11:04   #6 (permalink)
Member: 2022385
Sonork: 166633
Thanks Meter: 71
try this way
in phone turn on call to *#*#889988#*#* then go to gprs then write your imei and restart your phone.
maybe it help you.
press thanks if it was useful.
The Following User Says Thank You to milad barsokh For This Useful Post:
Old 01-08-2014, 11:38   #7 (permalink)
Member: 1905774
Sonork: 100.1646709
Thanks Meter: 967
Model = SM-N9006
OS Version= 4.2.2
CPU TYPE = mt6572
CPU TYPE 2= MT6572
Rechecking Imei
contect with me on yahoo i am solove [email protected]
Old 01-08-2014, 11:46   #8 (permalink)
Member: 419331
Thanks Meter: 92
Question
Originally Posted by milad barsokh View Post
try this way
maybe it help you.
same problam not write
Old 01-08-2014, 13:03   #9 (permalink)
Member: 582476
Thanks Meter: 5
did you solve your problem, i have same issue in same model, china note 3 copy n9006.
Old 01-08-2014, 16:26   #10 (permalink)
eng imran's Avatar
Member: 1640158
Sonork: 100.1615555
Thanks Meter: 125
i also have same problem imei note 3 china copy
Old 01-08-2014, 21:06   #11 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 5,976
note3 ver. 4.3 imei write not posibal without flash
imei write success but after on auto restart and again old imei
like s4 mtk6577
find same ok phone read flash and write in faulty phone then write imei
Old 01-09-2014, 07:22   #12 (permalink)
shuvo007's Avatar
Member: 775086
Sonork: 100.1603609
Thanks Meter: 370
like s4 mtk6577
i agree with you.it is not possible without new firmware.
Old 01-09-2014, 07:36   #13 (permalink)
Member: 1612781
Thanks Meter: 13
try this tol MTKdroidTools 100% sackses phone on and conneck usb cabel and oppan MTKdroidTools waet complet mobile info and wrigt imei
Page generated in 0.50562 seconds with 7 queries
