05-22-2012, 10:15 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: IN THIS WORLD Age: 44
Member: 49594 Status: Offline Thanks Meter: 39 | Please add this chip mt6252a wbr super boy24 |
05-22-2012, 10:48 | #2 (permalink) |
Product Supporter Join Date: Jun 2008 Location: TURBHE JANTA MARKETNAVI MUMBAI Age: 45
Member: 787829 Status: Offline Sonork: 100.1615114 Thanks Meter: 917 | already supported bro see here http://forum.gsmhosting.com/vbb/f723...olved-1456934/ use this procedure go to detect tab select proper cable from list select cpu type ( mstar D+ D-) connect phone click detect button and don't hold power button then click on set pinout now go back to mtk tab untick auto pinouts detect select operation you want (format. read flash. write flash. imei repair) and click run ( dont touch power button) as it is usb mode. try and post result. volcano ahead of all |
05-22-2012, 16:15 | #6 (permalink) | |
Member: 49594 Status: Offline Thanks Meter: 39 | Quote:
Code: Connecting... Connection successful,connected state! Version: V3.8 SN:08x-xx0-xxx Port:COM2 For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: null Detection initiated... >>Failed to detect. Code: Connecting... Connection successful,connected state! Version: V3.8 SN:08x-xxx-xxx Port:COM2 For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: 4 Gnd: 5 Detection initiated... >>Failed to detect. So where could be the problem because when i use a usb cable,VCC and GND are not detected but when i use the Tag cable there detected though in both cases D+ and D- ARE NOT detected. wbr super boy24 | |
05-22-2012, 16:26 | #7 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Quote:
Your Problem Not Solved Contact with me. | |
05-24-2012, 09:48 | #10 (permalink) |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Try this method go to detect tab select proper cable from list select cpu type ( mstar D+ D-) connect phone click detect button and don't hold power button then click on set pinout now go back to mtk tab untick auto pinouts detect select operation you want (format. read flash. write flash. imei repair) and click run ( dont touch power button) as it is usb mode. try and post result. if problem not solved contact me on sonork or yahoo |
05-24-2012, 09:50 | #11 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: pakistan
Member: 601913 Status: Offline Sonork: 100.1597350 Thanks Meter: 658 | Quote:
The Following User Says Thank You to r-jcomm For This Useful Post: |
05-24-2012, 10:25 | #13 (permalink) |
Banned Join Date: Jul 2011 Age: 32
Member: 1609044 Status: Offline Thanks Meter: 892 | some time this cpu not conect i face this problem many time than i use this soft and well conect formate ok FlashTool_v5.1112.00 |
The Following User Says Thank You to gsm_mithun For This Useful Post: |
05-24-2012, 13:05 | #14 (permalink) | |
Code: Detection initiated, connect the phone and power on it... Vcc: 4 Gnd: 5 7 Analyzing Rx and Tx... Individual phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... MT6250/6252, RX: 3, TX: 2, Pull up: 1 Setting... Pinouts setting complete! Connecting... Hardware version:CF00 Software version:0101 CPU TYPE:6250 Internal version:8B00 Boot downloading complete! Flash ID: 00C20025 Flash Type: SF_MX25U6435E Chip Capacity: 0x800000(8MB) Mobile phone software version for:FSWOND.DL5222 Baud adjust...complete. Read phone information success. Waiting for phone's response,please press Power on/off button Connecting... Hardware version:CF00 Software version:0101 CPU TYPE:6250 Internal version:8B00 Boot downloading complete! Flash ID: 00C20025 Flash Type: SF_MX25U6435E Chip Capacity: 0x800000(8MB) Mobile phone software version for:FSWOND.DL5222 Baud adjust...complete. Flash reading complete! usercode:1122 >>The data has been saved in C:\Users\Denis\Desktop\F900 SOZE52_6432_10A_PCB01_GPRS_MT6252>>Waiting for phone's Waiting for phone's response,please press Power on/off button... Connecting... Hardware version:CF00 Software version:0101 CPU TYPE:6250 Internal version:8B00 Boot downloading complete! Flash ID: 00C20025 Flash Type: SF_MX25U6435E Chip Capacity: 0x800000(8MB) Mobile phone software version for:FSWOND.DL5222 Baud adjust...complete. Format range: Start Address: 0x768000,Format Length :0x098000 Flash erasing complete! Waiting for phone's response,please press Power on/off button... Connecting... Hardware version:CF00 Software version:0101 CPU TYPE:6250 Internal version:8B00 Boot downloading complete! Flash ID: 00C20025 Flash Type: SF_MX25U6435E Chip Capacity: 0x800000(8MB) Mobile phone software version for:FSWOND.DL5222 Baud adjust...complete. >>Read phone information success. super boy24 | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
Sp unlocking sim - if you can get or sell please let me know | andrew bennett | Wanted Products | 1 | 09-24-1999 08:43 |
