02-01-2014, 14:25 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: iran-rafsanjan Age: 39
Member: 883516 Status: Offline Sonork: 100.1589551 Thanks Meter: 75 | pls give me solution for spread cpu 6530 and 6820 my box is black i have 2 problem with vocano box 1: i can't write reading file from android phon cpu spread 6820 in phone ( read from phone but show partition error when write phone ) 2: when write flash sprad cpu 6530 go for writing file but in 50% hang and volcano not stop and any work pls give me solution |
02-01-2014, 14:48 | #2 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | 6820 backup to factory mode , Create pac & flash with ResearchDownload If any error On flashing Post with Screenshots . Dont worry BIN write Add Soon For SPD Android 6530 its working with latest version Do backup with latest version Then Write with latest version If any error Post with Screenshots Br AzimBahar |
The Following User Says Thank You to aZimBahar For This Useful Post: |
02-01-2014, 15:11 | #3 (permalink) |
Member: 883516 Status: Offline Sonork: 100.1589551 Thanks Meter: 75 | tnx for answer phon after format is dead phone model is ccit z6 can you give me pac file for this model ? my box version is 2.4.9 but have problem with cpu spread 6530 and hang in 50% |
02-01-2014, 17:51 | #4 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Côte d'Ivoire_Ghana_Nigeria Age: 40
Member: 846968 Status: Offline Sonork: 100.1613167 Thanks Meter: 139 | can read code on this cpu spread 6530 i have open phoneto see which write on cpu but no work use direct cable and rx tx no work any solution |
The Following User Says Thank You to Maik_TechService For This Useful Post: |
02-01-2014, 18:29 | #5 (permalink) | |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Quote:
Brother No need use Volcano Main Cable.... Just use Micro USB Cable(ca-101).... Install SPD Driver ... Go to SPD tab .. Select Boot 13 .... UN tick Auto-Pin out Detect ... Insert Batter ... Press Boot Key (like Vol+,Vol-,home) until Start any Job ... Connect USB Cable.. Select Read ,Write,Format Etc .... Click Run .... If Face Any Problem Post Result With Screen Shot ..... Br, AniAXN | |
02-01-2014, 18:33 | #6 (permalink) | |
Where Is Screen Shot ...?? With out Any Shot We cant help you Properly ... Use Volcano latest Version ... Br, AniAXN | |
The Following User Says Thank You to AniAxn For This Useful Post: |
02-05-2014, 08:27 | #8 (permalink) |
Member: 883516 Status: Offline Sonork: 100.1589551 Thanks Meter: 75 | and this is screen shot cpu 6530 and hang in 50% |
The Following User Says Thank You to hossein_mobile For This Useful Post: |
02-05-2014, 09:40 | #9 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | @ hossein_mobile ..... Brother SPD 6820 / 8810 not Support in Write in Bin Format at this time.. Bin Format File Support Soon in Upcoming Update .... Or spd 6530 use latest version its full support .... Br, AniAXN Last edited by AniAxn; 02-05-2014 at 09:49. |
02-05-2014, 12:01 | #12 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Yes . Flow AniAxn You did backup with which version ? Old version can not read good file Br Azimbahar |
