03-15-2012, 11:43 | #61 (permalink) |
No Life Poster Join Date: Sep 2007 Location: EARTH Age: 42
Member: 582682 Status: Offline Sonork: 100.1607124 Thanks Meter: 136 | rokea r5570 succesfully HERE MY SUCCESS LOG 1) DONE SUCCESS READ CODE 2) READ FLASH 3) WRITE FLASH 4) PHONE RESET Volcano Updated: 2012-03-14 Connecting... Connection successful,connected state! Version: V3.8 SN:001-889-526 Port:COM41 Vcc: null Gnd: null Detection initiated, connect the phone and power on it... Identifying MT... Identifying SKY... Identifying SPD... User stop Vcc: null Gnd: 22 Detection initiated, connect the phone and power on it... Identifying MT... MT6250/6252, RX: 24, TX: 18 Detection completed with 4.50 seconds! Available Ports:COM1 COM5 COM7 COM21 COM22 COM28 COM36 COM37 COM41 Detection initiated, connect the phone and power on it... Vcc: null Gnd: 22 Analyzing Rx and Tx... User stop Pinouts are not fonud! Detection initiated, connect the phone and power on it... Port[COM41]lost or occupied.If it is occupied,please try again after terminate other programs! Vcc: null Gnd: 22 Analyzing Rx and Tx... Port[COM41]lost or occupied.If it is occupied,please try again after terminate other programs! MT6250/6252, RX: 24, TX: 18 Setting... Pinouts setting complete! Setting pinouts... Pinout setting complete. Detection initiated, connect the phone and power on it... Vcc: null Gnd: 22 Analyzing Rx and Tx... MT6250/6252, RX: 24, TX: 18 Setting... Pinouts setting complete! Detection initiated, connect the phone and power on it... Vcc: null Gnd: 22 Analyzing Rx and Tx... MT6250/6252, RX: 24, TX: 18 Setting... Waiting for phone's response,please press Power on/off button. Connecting... Hardware version:CA04 Software version:0100 CPU TYPE:6250 Internal version:8B00 Connecting, please hold on the power key... Formatting completed For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: 7 Gnd: 2 Detection initiated... D+ = 6, D- = 8 Detection D+/D- with 4.53 seconds! Continue to detect BOOT pin... Available Ports:COM1 COM5 COM7 COM21 COM22 COM28 COM34 COM35 COM36 COM37 The file is empty,please check it! The file is empty,please check it! User stop For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: 7 Gnd: 2 Detection initiated... D+ = 6, D- = 8 Detection D+/D- with 4.53 seconds! Continue to detect BOOT pin... User stop Setting pinouts... Pinout setting complete. Detection initiated... Vcc: 7 Gnd: 2 Analyzing D+ and D-... D+ = 6, D- = 8 Detection D+/D- with 4.53 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Please change Boot or reduce Baudrate, try it again. The file is empty,please check it! Setting pinouts... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) The file is empty,please check it! Pinout setting complete. The file is empty,please check it! Setting pinouts... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) The file is empty,please check it! Pinout setting complete. For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: 7 Gnd: 2 Detection initiated... D+ = 6, D- = 8 Detection D+/D- with 4.55 seconds! Continue to detect BOOT pin... User stop Setting pinouts... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) The file is empty,please check it! Pinout setting complete. Reset USB device and search it... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) Adding the cable's title... Cable title added successfully. The file is empty,please check it! The file is empty,please check it! The file is empty,please check it! For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: 7 Gnd: 2 Detection initiated... Found: D+ = 6, D- = 8 Detection D+/D- with 4.53 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Detection completed. Setting pinouts... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) The file is empty,please check it! Pinout setting complete. Waiting for phone's response, press the Power on the phone... Please change Boot or reduce Baudrate, try it again. Detection initiated... Vcc: 7 Gnd: 2 Analyzing D+ and D-... D+ = 6, D- = 8 Detection D+/D- with 4.55 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Please change Boot or reduce Baudrate, try it again. When R/W IMEI is COM, Detect Type should select 6600(COM) or 8800(COM) Detection initiated... Vcc: 7 Gnd: 2 Analyzing D+ and D-... D+ = 6, D- = 8 Detection D+/D- with 4.53 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... The 1st boot failure,Please reduce Baud-rate and try again! Please change Boot or reduce Baudrate, try it again. Detection initiated... Vcc: 7 Gnd: 2 Analyzing D+ and D-... D+ = 6, D- = 8 Detection D+/D- with 4.53 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... The 1st boot failure,Please reduce Baud-rate and try again! Please change Boot or reduce Baudrate, try it again. Detection initiated... Vcc: 7 Gnd: 2 Analyzing D+ and D-... D+ = 6, D- = 8 Detection D+/D- with 4.53 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Boot fileSpreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC6800H [68000000] Flash ID: 00AD0076 Flash Type:[Hyundai] HY27XS08121A/M/HYC0UEE0MF2P-6SH0E FLASH LEN:0x4000000 --------------------------------------. Phone imei lists. IMEI1:352642047658920 IMEI2:352642047658938 IMEI3:358570010103893 Read Info finish. The file is empty,please check it! Detection initiated... Vcc: 7 Gnd: 2 Analyzing D+ and D-... D+ = 6, D- = 8 Detection D+/D- with 4.53 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) Pinouts setting complete! Temporary does not support this guide to read the reset function Detection initiated... Vcc: 7 Gnd: 2 Analyzing D+ and D-... D+ = 6, D- = 8 Detection D+/D- with 4.53 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Boot fileSpreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC6800H [68000000] Flash ID: 00AD0076 Flash Type:[Hyundai] HY27XS08121A/M/HYC0UEE0MF2P-6SH0E FLASH LEN:0x4000000 Reading completed. Read time: 3 min 27 s The data has been saved in I:\volcanobox\spd\rokea manojbhai\MOCOR_PDA_1.2_Release_20120315_153442_Fu llFlash.bin, size: 66 M. Failes to open the file! Simple search: [privacy lock]:9 [privacy lock]:1234 [phone lock]:1234 Looking for passwords,please wait... [Privacy Lock] 1234 Looking for passwords complete. Detection initiated... Vcc: null Gnd: null Analyzing D+ and D-... Failed to detect. Pinouts are not fonud! Setting pinouts... Pinout setting complete. Detection initiated... Vcc: null Gnd: null Analyzing D+ and D-... Failed to detect. Pinouts are not fonud! For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: null Detection initiated... Failed to detect. Clearing pinouts... Clearing pinouts complete! For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: 18 23 Gnd: null Detection initiated... User stop C:\Program Files\FuriouS TeaM\VolcanoBox\PrtScn\PIC_2012_03_15_3_45_24_PM.j pg saved. Detection initiated... Vcc: 18 Gnd: 23 Analyzing D+ and D-... Failed to detect. Pinouts are not fonud! Detection initiated... Vcc: 7 Gnd: 2 Analyzing D+ and D-... D+ = 6, D- = 8 Detection D+/D- with 4.53 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Boot fileSpreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC6800H [68000000] Flash ID: 00AD0076 Flash Type:[Hyundai] HY27XS08121A/M/HYC0UEE0MF2P-6SH0E Set to Factory successfully. Detection initiated... Vcc: 7 Gnd: 2 Analyzing D+ and D-... D+ = 6, D- = 8 Detection D+/D- with 4.53 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM59), (VID_1782&PID_4D00) Pinouts setting complete! The file loaded is not integral,it can not be used to write full flash.Please backup before write! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Boot fileSpreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC6800H [68000000] Flash ID: 00AD0076 Flash Type:[Hyundai] HY27XS08121A/M/HYC0UEE0MF2P-6SH0E FLASH LEN:0x4000000 Writing completed. Flash file I:\volcanobox\spd\rokea manojbhai\MOCOR_PDA_1.2_Release_20120315_153442_Fu llFlash.bin has been written. >>Ready to read/write again, please remove the clip or battery and then re-loaded it. |
03-16-2012, 03:53 | #62 (permalink) |
No Life Poster Join Date: Jan 2012
Member: 1716315 Status: Offline Thanks Meter: 4,634 | Volcano Box the world Fastest 6800H flash Readers... Volcano Box Ahead of All Seems some people want to play with our balls... but one thing I dont understand... They claiming behing first at over 10min time of reading while we need less than 8 min Some users were telling us to focus on our work and forget others... Sorry about this but is important to make things clear But honestly,we dont want to compete speed, why we improve speed is just for the customers consideration and sake. We have the ability to searve customers well. Flash Read Featuring 128M Flash Flash Read Featuring 66M Flash More over we have some proof that some team copied our boot for their update... will give more details soon... Anyway I go back to work now we are working on somethign you guys will love Volcano Box...Ahead of all |
03-16-2012, 12:25 | #63 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Success Scan and READ FLASH CROSS AD202 ANDROID With Volcano Box Thanks REVOShop For Success Report Regard, Volcano Box Ahead of All |
The Following 3 Users Say Thank You to .::ARD::. For This Useful Post: |
03-16-2012, 15:46 | #65 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 752310 Status: Offline Sonork: 100.1614731 Thanks Meter: 35 | very very nice volcano team my problem solved successfully read security code thx a lot volcano team some Mstar phones need to set VCC or CHARGE pin for that you have to find charge pin and select after that click on mstar boot find and press on detect then you have to press and hold power button as it will detect then click on set pinout then go to mstar tab and untick from auto pinfind then click on readflash or write flash or readinfo it will works fine Last edited by Volcano Box; 03-17-2012 at 04:15. |
03-16-2012, 20:27 | #66 (permalink) |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | Volcano Box Successfully Unlocked / Repaired / Flashed Phones !!! log Detection initiated, connect the phone and power on it... Vcc: 9 Gnd: 2 Analyzing Rx and Tx... MT6225, RX: 4, TX: 1 Setting... Pinouts setting complete! Connecting... Hardware version:8A05 Software version:8A00 CPU TYPE:6225 Internal version:0000 CPUID :03E30F00 Boot downloading complete! Flash ID: 00EC2402 Flash Type: NOR_K5L2833ATA Chip Capacity: 0x1000000(16MB) Mobile phone software version for:MAUI.08B.W09.16.MP.V12.F1 Baud adjust...complete. Read phone information success. Waiting for phone's response,please press Power on/off button... Connecting... Hardware version:8A05 Software version:8A00 CPU TYPE:6225 Internal version:0000 CPUID :03E30F00 Boot downloading complete! Flash ID: 00EC2402 Flash Type: NOR_K5L2833ATA Chip Capacity: 0x1000000(16MB) Mobile phone software version for:MAUI.08B.W09.16.MP.V12.F1 Baud adjust...complete. Flash reading complete! usercode:0000 The data has been saved in C:\Users\Cellpoder\Desktop\avvio 505 volcano\XPHONE25_GEMINI_08B_PCB01_GPRS_MT6225_S00. MAUI_08B_W09_16_MP_V12_F1.BIN, size: 16 M. unlock process Waiting for phone's response,please press Power on/off button Connecting... Hardware version:8A05 Software version:8A00 CPU TYPE:6225 Internal version:0000 Connecting, please hold on the power key... Can loosen the phone is switched on key Start analysis flash internal data. >>Solution of complete network lock. |
03-16-2012, 20:27 | #67 (permalink) |
03-16-2012, 22:08 | #68 (permalink) |
Member: 138781 Status: Offline Thanks Meter: 850 | Volcano Box Successfully Unlocked / Repaired / Flashed Phones !!! log and picture Detection initiated, connect the phone and power on it... Vcc: 11 Gnd: 5 Analyzing Rx and Tx... MT6226MA, RX: 10, TX: 9 Setting... Pinouts setting complete! Waiting for phone's response,please press Power on/off button.. Connecting... Hardware version:8B02 Software version:8B01 CPU TYPE:6226 Internal version:8A00 CPUID :416CB0A7 Boot downloading complete! Flash ID: 0001227E Flash Type: NOR_S71PL254J Chip Capacity: 0x1000000(16MB) Mobile phone software version for:E2500.VE.TE.Q.01.07 Baud adjust...complete. Flash reading complete! The data has been saved in C:\Users\Cellpoder\Desktop\avvio 505 volcano\kyocera_e2500_K1000_PCB01_GPRS_MT6226M_S01 .E2500_VE_TE_Q_01_07.bin, size: 16 M. Waiting for phone's response,please press Power on/off button... Connecting... Hardware version:8B02 Software version:8B01 CPU TYPE:6226 Internal version:8A00 Connecting, please hold on the power key... Can loosen the phone is switched on key Start analysis flash internal data. >>Solution of complete network lock. same method to unlock the gpgdragon |
The Following User Says Thank You to cellcarcol For This Useful Post: |
03-17-2012, 09:30 | #69 (permalink) | |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | zong R221 unlock Done ! Quote:
The Following User Says Thank You to Shani3 For This Useful Post: |
03-17-2012, 09:42 | #70 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Indonesia(Jambi)
Member: 246444 Status: Offline Thanks Meter: 124 | Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 0.92 seconds! Analyzing USB device, please wait... Found [MSTAR]USB device:GCREADER USB Device,(VID_1B20&PID_0300) Setting... Find USB device:GCREADER USB Device, (VID_1B20&PID_0300) Pinouts setting complete! Connecting to phone... Connection success! Boot downloading finished. Flash Type: NUMONYX_M58LR256KT Flash ID: 0020880D00000000 Flash Size: 02000000h Read Size: 02000000h(32M) CPU : 8533x_family_series Flash Reading... Flash Reading finished Phone Lock or SIM Lock: 0000 7785 1122 Anti-theft lock: 460000 460001 4Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 0.92 seconds! Analyzing USB device, please wait... Found [MSTAR]USB device:GCREADER USB Device,(VID_1B20&PID_0300) Setting... Find USB device:GCREADER USB Device, (VID_1B20&PID_0300) Pinouts setting complete! Connecting to phone... Connection success! Boot downloading finished. Flash Type: NUMONYX_M58LR256KT Flash ID: 0020880D00000000 Flash Size: 02000000h Read Size: 02000000h(32M) CPU : 8533x_family_series Flash Reading... Flash Reading finished Phone Lock or SIM Lock: 0000 7785 1122 Anti-theft lock: 460000 460001 4 66001 466093 466011 3002 2991 57547 4660 4600 6099 6287 0000 screen lock: >>The data has been saved in C:\Documents and Settings\indra\Desktop\sementara\imo.bin, size: 32 M. |
03-17-2012, 09:42 | #71 (permalink) |
03-17-2012, 10:04 | #72 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Thanks for the hint Boss, i am excited about this tool(Volcano) the lava just spilled on this mstar cpu. 2012-03-17 8:50:14 AM >>Volcano Updated: 2012-03-14 2012-03-17 8:50:15 AM >>Connecting... 2012-03-17 8:50:17 AM >>Connection successful,connected state! 2012-03-17 8:50:17 AM >>Version: V3.8 2012-03-17 8:50:17 AM >>SN:008-145-984 2012-03-17 8:50:17 AM >>Port:COM17 2012-03-17 8:53:28 AM >>For many phones, charge pins need to be set in order to identify USB devices. 2012-03-17 8:53:28 AM >>Detecting D+ and D-... 2012-03-17 8:53:29 AM >>Vcc: null 2012-03-17 8:53:29 AM >>Gnd: 20 2012-03-17 8:53:29 AM >>Detection initiated... 2012-03-17 8:53:57 AM >>Found: D+ = 22, D- = 23 2012-03-17 8:53:57 AM >>Detection D+/D- with 27.73 seconds! 2012-03-17 8:53:57 AM >>Analyzing USB device, please wait... 2012-03-17 8:54:01 AM >>Found [MSTAR]USB device:GCREADER USB Device,(VID_1B20&PID_0300) 2012-03-17 8:54:01 AM >>Detection completed. 2012-03-17 8:54:20 AM >>Setting pinouts... 2012-03-17 8:54:30 AM >>Find USB device:GCREADER USB Device, (VID_1B20&PID_0300) 2012-03-17 8:54:30 AM >>Pinout setting complete. 2012-03-17 8:55:11 AM >>Setting pinouts... 2012-03-17 8:55:17 AM >>Find USB device:GCREADER USB Device, (VID_1B20&PID_0300) 2012-03-17 8:55:17 AM >>Pinout setting complete. 2012-03-17 8:55:34 AM >>Available Ports:COM4 COM5 COM6 COM13 COM14 COM15 COM17 2012-03-17 8:55:34 AM >>Current Port:COM17 2012-03-17 8:55:34 AM >>Connecting to phone... 0391792012 8:55:34 AM >>Connecting to phone... 2012-03-17 8:55:34 AM >>Connection success! 0391792012 8:55:34 AM >>Connection success! 2012-03-17 8:55:34 AM >>Boot downloading... 0391792012 8:55:34 AM >>Boot downloading... 2012-03-17 8:55:37 AM >>Flash Type: MACRONIX_MX25U6435E 0391792012 8:55:37 AM >>Flash Type: MACRONIX_MX25U6435E 2012-03-17 8:55:37 AM >>Flash ID: 00C2253700000000 0391792012 8:55:37 AM >>Flash ID: 00C2253700000000 2012-03-17 8:55:37 AM >>Flash Size: 00800000h 0391792012 8:55:37 AM >>Flash Size: 00800000h 2012-03-17 8:55:37 AM >>Read Size: 00800000h(8M) 0391792012 8:55:37 AM >>Read Size: 00800000h(8M) 2012-03-17 8:55:37 AM >>CPU : 8533d/8532_series 0391792012 8:55:37 AM >>CPU : 8533d/8532_series 2012-03-17 8:55:37 AM >>Flash Reading... 0391792012 8:55:37 AM >>Flash Reading... 2012-03-17 8:55:37 AM >>Flash Reading... 0391792012 8:55:37 AM >>Flash Reading... 2012-03-17 8:56:02 AM >>Phone Lock or SIM Lock: 2012-03-17 8:56:02 AM >>0000 2012-03-17 8:56:02 AM >>1989 2012-03-17 8:56:02 AM >>Anti-theft lock: 2012-03-17 8:56:02 AM >>460000 2012-03-17 8:56:02 AM >>460001 2012-03-17 8:56:03 AM >>466001 2012-03-17 8:56:03 AM >>466093 2012-03-17 8:56:03 AM >>466011 2012-03-17 8:56:03 AM >>4660 2012-03-17 8:56:03 AM >>66092 2012-03-17 8:56:03 AM >>screen lock: 2012-03-17 8:57:03 AM >>The data has been saved in C:\Program Files\FuriouS TeaM\VolcanoBox\Data\Kiano K4444.bin, size: 8 M. |
The Following User Says Thank You to fredinho For This Useful Post: |
03-17-2012, 10:09 | #73 (permalink) |
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | 2012-03-17 8:50:14 AM >>Volcano Updated: 2012-03-14 2012-03-17 8:50:15 AM >>Connecting... 2012-03-17 8:50:17 AM >>Connection successful,connected state! 2012-03-17 8:50:17 AM >>Version: V3.8 2012-03-17 8:50:17 AM >>SN:008-145-984 2012-03-17 8:50:17 AM >>Port:COM17 2012-03-17 8:53:28 AM >>For many phones, charge pins need to be set in order to identify USB devices. 2012-03-17 8:53:28 AM >>Detecting D+ and D-... 2012-03-17 8:53:29 AM >>Vcc: null 2012-03-17 8:53:29 AM >>Gnd: 20 2012-03-17 8:53:29 AM >>Detection initiated... 2012-03-17 8:53:57 AM >>Found: D+ = 22, D- = 23 2012-03-17 8:53:57 AM >>Detection D+/D- with 27.73 seconds! 2012-03-17 8:53:57 AM >>Analyzing USB device, please wait... 2012-03-17 8:54:01 AM >>Found [MSTAR]USB device:GCREADER USB Device,(VID_1B20&PID_0300) 2012-03-17 8:54:01 AM >>Detection completed. 2012-03-17 8:54:20 AM >>Setting pinouts... 2012-03-17 8:54:30 AM >>Find USB device:GCREADER USB Device, (VID_1B20&PID_0300) 2012-03-17 8:54:30 AM >>Pinout setting complete. 2012-03-17 8:55:11 AM >>Setting pinouts... 2012-03-17 8:55:17 AM >>Find USB device:GCREADER USB Device, (VID_1B20&PID_0300) 2012-03-17 8:55:17 AM >>Pinout setting complete. 2012-03-17 8:55:34 AM >>Available Ports:COM4 COM5 COM6 COM13 COM14 COM15 COM17 2012-03-17 8:55:34 AM >>Current Port:COM17 2012-03-17 8:55:34 AM >>Connecting to phone... 0391792012 8:55:34 AM >>Connecting to phone... 2012-03-17 8:55:34 AM >>Connection success! 0391792012 8:55:34 AM >>Connection success! 2012-03-17 8:55:34 AM >>Boot downloading... 0391792012 8:55:34 AM >>Boot downloading... 2012-03-17 8:55:37 AM >>Flash Type: MACRONIX_MX25U6435E 0391792012 8:55:37 AM >>Flash Type: MACRONIX_MX25U6435E 2012-03-17 8:55:37 AM >>Flash ID: 00C2253700000000 0391792012 8:55:37 AM >>Flash ID: 00C2253700000000 2012-03-17 8:55:37 AM >>Flash Size: 00800000h 0391792012 8:55:37 AM >>Flash Size: 00800000h 2012-03-17 8:55:37 AM >>Read Size: 00800000h(8M) 0391792012 8:55:37 AM >>Read Size: 00800000h(8M) 2012-03-17 8:55:37 AM >>CPU : 8533d/8532_series 0391792012 8:55:37 AM >>CPU : 8533d/8532_series 2012-03-17 8:55:37 AM >>Flash Reading... 0391792012 8:55:37 AM >>Flash Reading... 2012-03-17 8:55:37 AM >>Flash Reading... 0391792012 8:55:37 AM >>Flash Reading... 2012-03-17 8:56:02 AM >>Phone Lock or SIM Lock: 2012-03-17 8:56:02 AM >>0000 2012-03-17 8:56:02 AM >>1989 2012-03-17 8:56:02 AM >>Anti-theft lock: 2012-03-17 8:56:02 AM >>460000 2012-03-17 8:56:02 AM >>460001 2012-03-17 8:56:03 AM >>466001 2012-03-17 8:56:03 AM >>466093 2012-03-17 8:56:03 AM >>466011 2012-03-17 8:56:03 AM >>4660 2012-03-17 8:56:03 AM >>66092 2012-03-17 8:56:03 AM >>screen lock: 2012-03-17 8:57:03 AM >>The data has been saved in C:\Program Files\FuriouS TeaM\VolcanoBox\Data\Kiano K4444.bin, size: 8 M. |
