Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Volcano Box
Old 10-09-2013, 12:02   #31 (permalink)
..::One-Man::..'s Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,705
How To Wipe Android Phone & Tablet To Fastboot Mode
Note - This Way Work On All Android Phone
  • Open Your Volcano Latest Software
  • Entry Phone To Fastboot Mode
  • Connect To PC & Install Driver
  • Select FastBoot To Volcano
  • Unmark Auto Pinout
  • Select Wipe All
  • Now Run
  • Enjoy
HUAWEI S7-301u How To Entry : Volume Up & Powe
HUAWEI S7-301u Wipe Done On FastBoot Mode
HUAWEI S7-301u FastBoot Logo
How To Wipe Android Phone & Tablet To Fastboot Mode / HUAWEI S7-301u Wipe Done :)
Br,
..::AzimBahar::..
The Following User Says Thank You to ..::One-Man::.. For This Useful Post:
Old 10-10-2013, 04:42   #32 (permalink)
Member: 1174508
Sonork: 100.1593820
MTK 65xx New Method For IMEI Repair :)
MTK 65xxNew Method For IMEI Repair
How To Repair MTK 65XX IMEI :
  • Open Volcano Latest Version
  • Go To MTK TAB
  • Do Enable IMEI ( Using Ctrl+Alt+ I ) Then Yes
  • Click On Android tool
  • Click To Run
  • Click To MTK 65xx New Method
  • Entry IMEI To Box
  • Click To Write IMEI
  • When Software Saying Searching For Port
  • Insert Usb Cable to phone in powered OFF Condition !!
  • Install CDC Driver
  • Waiting For Process Complete
  • After 2 Sec Your IMEI Repair Done
If You Need CDC Driver : Android_Gadget_CDC_driver Or mtk android cdc and vcom.rar
We,
Volcano Team
The Following 2 Users Say Thank You to ..::One-Man::.. For This Useful Post:
Old 10-13-2013, 11:49   #33 (permalink)
Member: 1174508
Sonork: 100.1593820
How To Entry Samsung Download Mode With Volcano
How To Entry Download Mode With Volcano :
  • Open Volcano Soft
  • Go To Detect Tab
  • Select Cable E115
  • Manually Put REA To 4 & REB To 5
  • Now You Will See Reisistance Input BOX
  • Now Entry 300 Then Click Ok
  • Now Click To Set Pinout
  • After Pinout Setting Completed Put JIG (P-05B) To Main Cable
  • Now Remove Battery From Phone Then Put Again
  • Put Volcano Main Cable Jig To Phone
  • Now You Will See Download Mode
Enjoy Volcano Multi Power Tell Your Friends About Volcano
More Info Here
Br,
AzimBahar
Old 10-16-2013, 17:36   #34 (permalink)
Member: 1174508
Sonork: 100.1593820
How To Connect MTK Android Using USB & Magic Cable :
How To Connect MTK Android Using USB :
  • Open Volcano Latest Software
  • Click To MTK Tab
  • Select Android Boot {V7.1216 (Select Other Android Boot If You Get Any Error)}
  • Select Read Info , Format Or What You Want
  • Unmark Auto Detect Pinout
  • Select Usb Mode
  • Click Run
  • Now Press Boot Key Then Connect With Usb To PC
How To Connect MTK Android With Magic Cable:
  • Click To MTK Tab
  • Select Usb Mode
  • Click Run
  • Now Connect Phone With Magic Cable (No Need Press Boot Key Because U Use Magic Cable
Br,
AzimBahar
Old 10-17-2013, 10:43   #35 (permalink)
Member: 1174508
Sonork: 100.1593820
How To Connect Mstar Clip To Volcano
How To Connect MSTAR Clip Using Detect Tab :
  • Go To Detect Tab
  • Select [D+/D-]MTK USB&Mstar (Do Find Boot) To Detect Type
  • Now Select Manually VCC To (01)
  • Click To Detect & Press Power Switch If Not Detect Press Boot Key
    (Some Phone No Need Press Any Key , That Auto Detect ) Some Phone In PCB Have Boot Point (Like Tx Rx) That You Need Connect Boot Point To GND
  • After Pinout Detected Click To Set pinout
  • Now Go To Mstar Tab Unmark Auto Detect Pinout
  • Select Your Option Read Info , Read Flash , Write Flash ETC What You Want
  • Now Click To Run
Another Way How To Connect Using Detect Tab :
  • Go To Detect Tab
  • Select [Other]Charge Pin To Detect Type
  • Now Click To Detect
  • Click To Yes Then Click To No
  • Now Phone Auto VCC Set
  • Again Select [D+/D-]MTK USB&Mstar (Do Find Boot) To Detect Type
  • Now Click To Run
Note - If Usb Disconnect From Box Com Post , Then Just Go Detect Tab Then Click To Set pinout Then Go Mstar Tab & Do
How To Connect Mstar Clip Using Modify Cable (Magic Cable) :
  • Go To Mstar Tab
  • Phone Connect To Modify Cable
  • Click To Run
Info - If Every Way You Feel Any Error To Boot Downloading Then Select Correct Mstar Boot
Br,
AzimBahar
Old 10-17-2013, 11:42   #36 (permalink)
Member: 1174508
Sonork: 100.1593820
How To Write MTK IMEI (625A) To AT Mode
How To Write MTK IMEI (625A) To AT Mode :
  • Turn On The Phone
  • Connect To PC Using USB Cable
  • Now Select PC Suite / COM
  • Install Driver
  • Go To MTK Tab
  • Enable Imei Option
  • Select ''Write IMEI''
  • Mark USB Mode
  • Now Click To Run
  • Select Phone Port ( COM PORT )
  • Select AT If Already Not Selected
  • Entry IMEI
  • Click To ""Write IMEI(W)""
  • Wait Until Done
Enjoy Volcano
Br,
AzimBahar
Old 10-17-2013, 12:13   #37 (permalink)
Member: 1174508
Sonork: 100.1593820
How To Connect MTK Using Detect Tab :
  • Go To Detect Tab
  • Select To Detect Type "" [D+/D-]MTK USB & Mstar (Do Find Boot)
  • Connect Phone To Volcano Main Cable
  • Click To Detect
  • Press Power Key If Not Detect Then Boot Key {Note-Some Pone Auto Detect, No Need Press Any Key & Some Phone In PCB Have Boot Point (Like TX RX ) That Phone For Booting You Need Connect Boot Point To GND}
  • After Pinout Detected Click To Set Pinout
  • Now Go To MTK Tab
  • Select USB Mode
  • Now Select Correct MTK Boot
  • Select Read Write Format What You Want
  • Run
Enjoy
Br,
AzimBahar
Old 10-29-2013, 08:24   #38 (permalink)
4star's Avatar
Member: 1596162
Sonork: 100.1616391
Thanks Meter: 83
VOLCANO BOX USB DEVICE NOT RECOGNIZED 100% TESTED ME
Old 10-30-2013, 04:16   #39 (permalink)
Member: 1174508
Sonork: 100.1593820
How to Read & Write NV for MTK Andriod ?
How To Backup NV :
  1. Your phone must be ROOTED & Debug Mode on & Powered on phone
  2. Connect Phone with usb
  3. Download & Run VolcanoBox Latest Version
  4. Go to MTK Tab -> One-Click Root -> Backup NVRam
  5. Run
How To Write NV :
  4. Go to MTK Tab -> One-Click Root -> Write NVram
  5. Run
Br,
AzimBahar
The Following 17 Users Say Thank You to ..::One-Man::.. For This Useful Post:
Old 10-30-2013, 05:49   #40 (permalink)
Member: 1552632
Sonork: 0000
Thanks Meter: 24
Lets Know About Android Tools
Where To Download ADB & Fastboot Driver
All Android Phone & Tablet ADB & FastBoot Windows Driver For Volcano Android Tools
in Android Tool
USB MODE ( Boot mode )
Read info
Read Flash
Write Flash
Read NVRAM
Write NVRAM
Root with Boot ( this is not ADB ROOT )
Recovery
Format ( Auto & Manual Both )
Rebuild Imei ( Changing of imei is illegal )
4 Imeis can rebuild
MTK & SPD Phones Supported
ADB MODE( Powered on and usb debug enabled )
Is ADB ( to check is phone is attached correctly or not )
ADB Root ( to root phone in usb debug mode enabled )
Wipe_ALL ( to wipe phone's data in usb debug mode enabled and phone must be rooted )
BACKUP FLASH ( to take backup of flash file phone should be rooted and usb debug mode enabled )
Backup NvRam ( to take backup of NV )
IS ROOT ( to check is phone rooted or not )
ADB UNROOT ( to unroot phone via adb method phone should be powered on and usb debug enabled )
Reset Gmail ( to reset Gmail account which Android phone asking after too many pattern attempts )
Unlock ( to unlock phone... Not SP UNLOCK )
Write NVram ( to write back Nv )
TABLET
IS ADB ( to check is Tablet connected well to your pc & usb debug enabled )
ROOT ( to root tablets make sure tablet is powered on & usb debug enabled )
Read NV ( to read tablets nv )
IS ROOT ( to check is tablet rooted or not )
UNLOCK ( to unlock )
WRITE NV ( to write NV back to Tablet )
FASTBOOT
IS FASTBOOT ( To check is phone is connected correctly in fastboot mode )
WIPE USERDATA ( to clear all data and make factory reset can solve pattern lock & gmail account etc )
EXIT FASTBOOT ( to exit fastboot mode phone will restart into normal mode )
WIPE CACHE ( to wipe/delete all cache )
BACKUP FILE ( to create backup files phone should be in fastboot mode )
WRITE FILE ( to write Boot, Recovery, System, Data, Cache & Update.zip )
HTC Phone ( to get MIDINFO, CIDINFO, Write OEMCID, Write SuperCID & IdentifyINFO )
MODEM
IS MODEM ( is modem connected successfully )
PHONE INFO ( information about connected device )
TOOL
Root Tool ( to slip, Merge & CVT File )
File Version ( to know what kind of ver is in your Flash file )
The Following 21 Users Say Thank You to aslamshaikh For This Useful Post:
Old 11-02-2013, 19:15   #41 (permalink)
Member: 1174508
Sonork: 100.1593820
how to enable USB debugging?
As for enabling USB debugging in Android 2.3 or newer can be done by..
  1. Open the Settings.
  2. Now tap on “Applications”.
  3. And then go to “Development”.
  4. Check the option: “USB debugging”
As for enabling USB debugging in Android 4.0 or newer can be done by...
  2. Search then Tap on “Developer options”.
  3. Check the option: “USB debugging”.
As for enabling USB debugging in Android 4.2 or newer can be done by...
  1. Open Settings > About.
  2. Go to “Build Number” at the end of the Scroll list.
  3. Tap that “Build Number” repeatedly for 7 times. But on the third tap, you will be presented with a message saying you only 4 more taps to be a developer. Therefore continue tapping till "Hooray, you are now a ‘Developer’ appears, at this phase the go back to Setting page.
  4. Now Developer Option will be included in setting list of yours now.
  5. Launch Developer Options, then check USB debugging > Ok. Done!
Once it's enabled you, even as non-developer you will get a level of access over your device to give you bigger freedom in controlling your device.
Br,
AzimBahar
The Following 14 Users Say Thank You to ..::One-Man::.. For This Useful Post:
Old 11-02-2013, 19:23   #42 (permalink)
Member: 1174508
Sonork: 100.1593820
How To Know My Android Device Already Enable USB Debugging?
How To Know My Android Device Already Enable USB Debugging...?
  • Turn On The Device
  • Connect To PC Using USB CABLE
  • Now If Go To Device Manager
  • Install Driver
  • Now If You See " ADB Interface " That Means Device Degag Enable
Look
Driver Successfully Install Done
You See On The Screenshot ADB Interface
Br,
AzimBahar
The Following 8 Users Say Thank You to ..::One-Man::.. For This Useful Post:
Old 11-02-2013, 21:39   #43 (permalink)
Member: 1174508
Sonork: 100.1593820
How To Check Any Android Device Info To ADB MODE
How To Check Device Info To ADB MODE:
  • Open Volcano Software
  • Go To Android Tab
  • Click To ADB MODE Tab
  • Now Select IS ADB
  • Click To Start
  • Now You Will See Device Info ( Model : Android Version : Baseband : IMEI )
Device Info Read Done
Br,
AzimBahar
The Following 7 Users Say Thank You to ..::One-Man::.. For This Useful Post:
Old 11-02-2013, 21:42   #44 (permalink)
Member: 1174508
Sonork: 100.1593820
How To Check Any Device Root Or Unrooted To ADB Mode
How To Check Device Rooted Or Unrooted To ADB Mode:
  • Go To Android Tablet
  • Select IS ROOT
  • Click To Start
  • Now You Will See Device Root Info ( Already Rooted Or Unrooted )
Device Rooted Or Unrooted Check Done
Br,
AzimBahar
The Following 4 Users Say Thank You to ..::One-Man::.. For This Useful Post:
Old 11-02-2013, 21:50   #45 (permalink)
Member: 1174508
Sonork: 100.1593820
How To Root Any Android To ADB Mode :
  • Select ADB ROOT
  • CLICK TO START
  • NOW Wait For Have Been Rooted
Root Done
Br,
AzimBahar
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 11:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 04:52
Unlock Manual! MrProdent Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-12-2004 09:13
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.60723 seconds with 8 queries
