02-21-2014, 08:25 | #76 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: DAVAO
Member: 2082354 Status: Offline Sonork: 564788686887 Thanks Meter: 115 | OPEN VOLCANO OPEN ANDROID TAB as you can see ZTE V795 is not in list select what in picture LOGS Partition: SEC_RO Start = 0X2F80000 Len = 0X40000 Partition: MISC Start = 0X2FC0000 Len = 0X80000 Partition: LOGO Start = 0X3040000 Len = 0X300000 Partition: EXPDB Start = 0X3340000 Len = 0XA00000 Partition: ANDROID Start = 0X3D40000 Len = 0X28A00000 Partition: CACHE Start = 0X2C740000 Len = 0X17800000 Partition: USRDATA Start = 0X43F40000 Len = 0X52C00000 Partition: FAT Start = 0X96B40000 Len = 0X4F5C0000 Partition: BMTPOOL Start = 0XFFFF00A8 Len = 0X0 DOWNLOAD INFORMATION!! Version: V1.0 Ram checksum: DRAM_PASS Download status: DL_CK_DONE Image: MBR : PASS Image: EBR1 : PASS Image: UBOOT : PASS Block2(NS):Unlocked Code: 56781234 Block3(SP):Unlocked Code: 11112222 Block4(C ):Unlocked Code: 33334444 Block5(SIM):Unlocked Code: 55556666 Start direct unlock... Simlock Info : Sim(2) Block1(N ):Locked (remain:1) Code : 12345678 Block2(NS):Unlocked Code: 56781234 Block3(SP):Unlocked Code: 11112222 Block4(C ):Unlocked Code: 33334444 Block5(SIM):Unlocked Code: 55556666 Start direct unlock... All done. |
03-25-2014, 06:29 | #77 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | How To flash MTK Android With Factory (FAC) File Using Volcano How To flash MTK Android With Factory (FAC) File Using Volcano Open Volcano Android Tools & Select Go To USB Tab Select Write FAC File & Click Start Now Select Sactter File & Click Ok See Setting Ok Now Your Volcano Searching For Port Connect Phone To Boot Mode Flashing Start On Flashing ...... Flashing Done Br One-Man ..::AzimBahar::.. |
The Following 3 Users Say Thank You to aZimBahar For This Useful Post: |
11-16-2014, 21:48 | #78 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | How to Write IMEI in SPD 6820/8810 Using New Method with Volcano .. How to Write IMEI in SPD 6820/8810 Using New Method with Volcano Run Latest Volcano Exe .. Go Detect Tab & Sey Pin-Out Manually After Set Pin-out Remove Main Cable From Box Now Go SPD Tab & Enable Imei & Select This Step A New Window Come like Bellow Now Fill The Phone Original IMEI on IMEI Box Click To Start .. Now Connect Main Cable to Box When IMEI box Show Green Box Like Bellow Now IMEI write Complete See The IMEI After Rebuild Wbr, AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
11-16-2014, 21:51 | #79 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | How To Enter Recovery Mode Using Shift Mode using Volcano How To Enter Recovery Mode Using Shift Mode using Volcano Just Enter Factory Mode any Spd or MTK Android Connect USB Cable Phone will Connect via ADB Run Volcano & Go ADB Mode Now Phone Come on Recovery Mode Wbr, AniAXN |
08-05-2015, 15:13 | #82 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Pakistan Karachi Age: 28
Member: 1311812 Status: Offline Sonork: 1659061 Thanks Meter: 116 | Volcano Box Driver Code 10 Error Solution for Windows 10 or 8 Users Hy all i am facing that problem in windows 10 i have searched more and more but in vain to solve that issue finally i have find a way to solve that problem have a look here.... After Installing the drivers: And he gets the "Code 10" error: Now fix that problem with Profilic_Win8_x64_x86.zip Extract the contents of this file: Right click the .inf file, and select "Install". Then Update the Drivers again: In the resulting dialog, click "Browse my computer for driver software": Select "Let me pick from a list of device drivers on my computer": Select the Prolific driver version 3.3.2 from 2008: Drivers will install fine and works ok so that is all.. Check this and post results if you like it click Thanks botton <3 Best Regards Gohar Abbas Last edited by goherabbas; 08-05-2015 at 15:19. Reason: Pictures problem |
08-10-2015, 06:53 | #84 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | How to Erase MTK Full Flash with Volcano Box How to Erase MTK Full Flash with Volcano Box Why need to Full Erase ? Many time User Face No Service , No Network , Unknown Base-band or similar Problem on MTK Android .That time Need to do Full Flash Erase .
Now The Phone is Full Erased[Dead Condition] Note - Before Do any think always make backup first or Keep Stock Rom on your PC . Because after full erase your Phone will Dead . Now need to Write Full Firmware to Alive Phone .. Wbr, AniAXN Last edited by AniAxn; 08-10-2015 at 07:15. |
11-06-2015, 20:08 | #85 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Arizona Age: 38
Member: 630795 Status: Offline Thanks Meter: 177 | How to Avoid tablet stuck at logo when flashing with Volcano Backup Hello , If u want to backup a tablet flash file with Volcano You have to do the following things in order to make it work again on the same tablet or same Board ID . Or you will stuck at logo. First You have to read info via volcano (this is the most important thing) eg: Code: analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:MT6572 Hardware version:CA01 Software version:0000 SecCfgVal :0x00000000 BromVersion :0xFF BLVersion :0x01 Boot downloading complete! EMMC_ID:0x8801034E4361726420356C07301152E1 EMMC_PRODUCT_NAME: SAMSUNG :0x4E4361726420 EMMC_BOOT1_SIZE: 0x00400000 EMMC_BOOT2_SIZE: 0x00400000 EMMC_PRMB_SIZE: 0x00020000 EMMC_GP1_SIZE: 0x00000000 EMMC_GP2_SIZE: 0x00000000 EMMC_GP3_SIZE: 0x00000000 EMMC_GP4_SIZE: 0x00000000 EMMC_USER_SIZE: 0x1CE100000(7.22 G) Analysis of system files... PRELOADER: addr:0x000000 --length:0xA00000 MBR: addr:0xA00000 --length:0x080000 EBR1: addr:0xA80000 --length:0x080000 PRO_INFO: addr:0xB00000 --length:0x300000 NVRAM: addr:0xE00000 --length:0x500000 PROTECT_F: addr:0x1300000 --length:0xA00000 PROTECT_S: addr:0x1D00000 --length:0xA00000 SECCFG: addr:0x2700000 --length:0x020000 UBOOT: addr:0x2720000 --length:0x060000 BOOTIMG: addr:0x2780000 --length:0x600000 RECOVERY: addr:0x2D80000 --length:0x600000 SEC_RO: addr:0x3380000 --length:0x040000 MISC: addr:0x33C0000 --length:0x080000 LOGO: addr:0x3440000 --length:0x300000 EXPDB: addr:0x3740000 --length:0xA00000 ANDROID: addr:0x4140000 --length:0x35200000 CACHE: addr:0x39340000 --length:0x17800000 USRDATA: addr:0x50B40000 --length:0x81700000 FAT: addr:0xD2240000 --length:0xFB1E0000 BMTPOOL: addr:0xFFFF00A8 --length:0x1500000 Format addr:0x50B40000 --Format length:0x81700000 Read phone information success. >>Not find lock data . Now : if you Write back the same backup for the same tablet, your tablet will stuck at logo and you will not be able to reset user data in recovery (you will face problem Error Mount Data) Where is the problem? The problem is in Scatter File If you look at Starting addresses in the Analysis of system files u first make by volcano , You will see that it is different from addresses in The scatter file made by volcano when backing up... Like this example : info before backup: Code: Analysis of system files... PRELOADER: addr:0x000000 --length:0xA00000 MBR: addr:0xA00000 --length:0x080000 EBR1: addr:0xA80000 --length:0x080000 PRO_INFO: addr:0xB00000 --length:0x300000 NVRAM: addr:0xE00000 --length:0x500000 PROTECT_F: addr:0x1300000 --length:0xA00000 PROTECT_S: addr:0x1D00000 --length:0xA00000 SECCFG: addr:0x2700000 --length:0x020000 UBOOT: addr:0x2720000 --length:0x060000 BOOTIMG: addr:0x2780000 --length:0x600000 RECOVERY: addr:0x2D80000 --length:0x600000 SEC_RO: addr:0x3380000 --length:0x040000 MISC: addr:0x33C0000 --length:0x080000 LOGO: addr:0x3440000 --length:0x300000 EXPDB: addr:0x3740000 --length:0xA00000 ANDROID: addr:0x4140000 --length:0x35200000 CACHE: addr:0x39340000 --length:0x17800000 USRDATA: addr:0x50B40000 --length:0x81700000 FAT: addr:0xD2240000 --length:0xFB1E0000 BMTPOOL: addr:0xFFFF00A8 --length:0x1500000 Code: ############################################################################################################ # # General Setting # ############################################################################################################ - general: MTK_PLATFORM_CFG info: - config_version: V1.1.1 platform: MT6572 project: C808 storage: EMMC boot_channel: MSDC_0 block_size: 0x40000 ############################################################################################################ # # Layout Setting # ############################################################################################################ - partition_index: SYS0 partition_name: PRELOADER file_name: preloader is_download: true type: SV5_BL_BIN linear_start_addr: 0x0 physical_start_addr: 0x0 partition_size: 0xA00000 region: EMMC_BOOT_1 storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: BOOTLOADERS reserve: 0x0 - partition_index: SYS1 partition_name: MBR file_name: MBR is_download: true type: NORMAL_ROM linear_start_addr: 0x1400000 physical_start_addr: 0x0 partition_size: 0x80000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x0 - partition_index: SYS2 partition_name: EBR1 file_name: EBR1 is_download: true type: NORMAL_ROM linear_start_addr: 0x1480000 physical_start_addr: 0x0 partition_size: 0x80000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x0 - partition_index: SYS3 partition_name: PRO_INFO file_name: PRO_INFO is_download: false type: NONE linear_start_addr: 0x1500000 physical_start_addr: 0x0 partition_size: 0x300000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: PROTECTED reserve: 0x0 - partition_index: SYS4 partition_name: NVRAM file_name: nvram is_download: false type: NONE linear_start_addr: 0x1800000 physical_start_addr: 0x0 partition_size: 0x500000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: BINREGION reserve: 0x0 - partition_index: SYS5 partition_name: _PROTECT_F file_name: protect_f is_download: false type: NONE linear_start_addr: 0x1D00000 physical_start_addr: 0x0 partition_size: 0xA00000 region: NONE storage: boundary_check: false is_reserved: false operation_type: reserve: 0x0 - partition_index: SYS6 partition_name: _PROTECT_S file_name: protect_s is_download: false type: NONE linear_start_addr: 0x2700000 physical_start_addr: 0x0 partition_size: 0xA00000 region: NONE storage: boundary_check: false is_reserved: false operation_type: reserve: 0x0 - partition_index: SYS7 partition_name: SECCFG file_name: seccfg is_download: false type: NONE linear_start_addr: 0x3100000 physical_start_addr: 0x0 partition_size: 0x20000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE reserve: 0x0 - partition_index: SYS8 partition_name: UBOOT file_name: uboot is_download: true type: NORMAL_ROM linear_start_addr: 0x3120000 physical_start_addr: 0x0 partition_size: 0x60000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x0 - partition_index: SYS9 partition_name: BOOTIMG file_name: boot is_download: true type: NORMAL_ROM linear_start_addr: 0x3180000 physical_start_addr: 0x0 partition_size: 0x600000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x0 - partition_index: SYS10 partition_name: RECOVERY file_name: recovery is_download: true type: NORMAL_ROM linear_start_addr: 0x3780000 physical_start_addr: 0x0 partition_size: 0x600000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x0 - partition_index: SYS11 partition_name: SEC_RO file_name: secro is_download: true type: NORMAL_ROM linear_start_addr: 0x3D80000 physical_start_addr: 0x0 partition_size: 0x40000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x0 - partition_index: SYS12 partition_name: MISC file_name: misc is_download: false type: NONE linear_start_addr: 0x3DC0000 physical_start_addr: 0x0 partition_size: 0x80000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE reserve: 0x0 - partition_index: SYS13 partition_name: LOGO file_name: logo is_download: true type: NORMAL_ROM linear_start_addr: 0x3E40000 physical_start_addr: 0x0 partition_size: 0x300000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x0 - partition_index: SYS14 partition_name: EXPDB file_name: expdb is_download: false type: NONE linear_start_addr: 0x4140000 physical_start_addr: 0x0 partition_size: 0xA00000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE reserve: 0x0 - partition_index: SYS15 partition_name: ANDROID file_name: system is_download: true type: YAFFS_IMG linear_start_addr: 0x4B40000 physical_start_addr: 0x0 partition_size: 0x35200000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x0 - partition_index: SYS16 partition_name: CACHE file_name: cache is_download: true type: YAFFS_IMG linear_start_addr: 0x39D40000 physical_start_addr: 0x0 partition_size: 0x17800000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x0 - partition_index: SYS17 partition_name: USRDATA file_name: userdata is_download: true type: YAFFS_IMG linear_start_addr: 0x51540000 physical_start_addr: 0x0 partition_size: 0x81700000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x0 - partition_index: SYS18 partition_name: FAT file_name: fat is_download: false type: NONE linear_start_addr: 0xD2C40000 physical_start_addr: 0x0 partition_size: 0xFFFFFFFFFB1E0000 region: NONE storage: boundary_check: false is_reserved: false operation_type: reserve: 0x0 - partition_index: SYS19 partition_name: BMTPOOL file_name: bmtpool is_download: false type: NONE linear_start_addr: 0xCD420000 physical_start_addr: 0x0 partition_size: 0x1500000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: false is_reserved: true operation_type: RESERVED reserve: 0x0 You can see the difference Solution Just edit the linear_start_addr for each partition in scatter file text .. Save the changes and you are done and you can safely flash the backup. Replace the address from the info you first read instead of the linear_start_addr in Scatter file. and thats it. You have to load files normally because scatter file will never load them. I hope this will help someone. |
03-27-2016, 21:59 | #88 (permalink) | |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Quote:
Hello, We have already a thread for this issue .. Post here with your box s/n on this thread .. http://forum.gsmhosting.com/vbb/f723...-here-1960047/ Wbr, AniAXN | |
05-12-2016, 21:31 | #90 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Cameroon
Member: 2049808 Status: Offline Thanks Meter: 7 | HOW to remove "Privacy protection password" to alcatel OT 4013D first do read info read and save flash after do unlock theft after format phone reboot without privacy protection here phone after unlock |
The Following User Says Thank You to johnnystrong For This Useful Post: |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
Unlock Manual! | MrProdent | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-12-2004 09:13 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
