05-28-2017, 03:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pb - BRAZIL
Member: 689942 Status: Offline Thanks Meter: 312 | Problem to remove account from xiaomi mi5. [ANSWERED] 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Port Found[COM20]. >>Hardware Id:009470e1 >>Loading Necessary File,Please Wait... >>Done. >>Waiting for flash programmer to boot. >>Status: 21 >>Get Partition Info Fail. obs: I downgrade and the device is in the MIUI Global 7.5 version, I can use the device but if I upgrade to the version MIUI V8.1.2.0 the device is locked again |
05-28-2017, 07:24 | #2 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Drivers issue only.UN-INSTALL drivers and RE-INSTALL again drivers.Also you can use SAFE MI REMOVE method on ADB&FastbootTools. BR. Sehar GPG Team BR. Sehar GPG Team |
06-25-2017, 07:59 | #3 (permalink) | |
Member: 689942 Status: Offline Thanks Meter: 312 | Quote:
Same problem, I tried on 3 different computers and it did not work. In fastboot mode, the program does however remain locked | |
