12-30-2014, 23:05 | #1 (permalink) |
Insane Poster Join Date: May 2013
Member: 1929852 Status: Offline Thanks Meter: 3 | Problem with SPD SC6610 [Answered] |
12-31-2014, 08:01 | #2 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hello .. Run Volcano 2.5.0 .. Go to SPD tab & Select Boot 2(6610/20) .. Do Read Flash .. Next Select Unlock code & Do Run .. A new window will came .. Just Select here Phone Backup File .. Password will Show in Logs .. For More Details Follow - Volcano Box Solutions / Manuals / Tutorial Wbr, AniAXN |
12-31-2014, 14:19 | #4 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Both are cable Supported .. If you use Normal USB Cable you must need to press boot key .. Or if you use P05B(jig) .. No need to press boot key .. Just Connect Volcano main cable with P05B(jig) .. & Do you Job .. Wbr, AniAXN |
12-31-2014, 15:34 | #7 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | You can use any version from both of them connect set on volcano main cable and do your work read flash then read password then power you mobile and put password that's it if any problem post screen shot also follow tutorial link by AniAxn . |
12-31-2014, 15:45 | #8 (permalink) |
Member: 1929852 Status: Offline Thanks Meter: 3 | Still nothing, i'm conecting the phone turned off without batter to the volcano cable set + and - of battery connectors and jig P05B (i guess this is the one cuz is like blackberry connector) and run but nothing here is the screen shot please help me |
12-31-2014, 16:00 | #9 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hello ... If you Use RX/TX via P05B(jig) on spd chip .. Its not support .. Because your phone have VCC/D-/D+/Boot/GND paint .. Only USB mode [D+/D-] Support P05B(jig) .. If you work with RX/TX [Com Port] .. You must sold RX/TX point on Phone PCB .. Wbr, AniAXN |
12-31-2014, 18:28 | #11 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Quote:
U didn't follow them correctly. 1 Sold RX & TX points to the pcb. 2 Open volcano detect tab. 3 select detect type as 'spd(rx&tx). 4 then click on detect. 5 After detection completed, click on set pinout. 6 Then select boot 2 in spd tab. 7 Change baudrate to 11500. 8 Select read flash, untick auto detect pinout. Then press run. Here u don't need to press boot key. Note: u must install the spd driver before doing any operations. Post result. Wbr Chandan | |
The Following 2 Users Say Thank You to chandanps18 For This Useful Post: |
03-18-2015, 06:26 | #13 (permalink) |
Junior Member Join Date: Jul 2013 Location: Venezuela
Member: 1980865 Status: Offline Thanks Meter: 1 | Help plz me and found this firmware but the SPD6531 model for those who need spd6530_00400000_gd25lq32_telego_c3782 - Descarga - 4shared I need firmware SPD6610 is Telego C3782 |
03-18-2015, 07:03 | #14 (permalink) | |
May be the thread starter have this file with him. Ask him for the file... Br | |
