09-22-2014, 06:18 | #1 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Pakistan
Member: 1771086 Status: Offline Thanks Meter: 2,410 | Q MOBILE A7 in problem 1 Unfortunately,Play Store has Stopped....... when i power on mobile then always show Error in Display.. 1 Unfortunately,Play Store has Stopped....... 2 Unfortunately,9Apps has Stopped. when i press OK then show another Error in display 3 if i do mobile restart after on mobile ..auto Massaging incoming with out Sim card i do full flashing but problem same i do Format problem same i do flashing 5 time another bther file problem same so plz some explain ox o 4 i do also uninstall all apps in mobile after uninstalling all apps .then i do restart mobile ...when mobile on show same error all apps in mobile show if mobile on then i format internal Memory ...mobile memory format via pc problem same formatting OK but all data show in mobile .............. |
The Following 2 Users Say Thank You to fahad ali khan For This Useful Post: |
09-22-2014, 06:37 | #2 (permalink) | |
Product Manager Join Date: Jul 2009 Location: GsmGenesis
Member: 1084080 Status: Offline Thanks Meter: 8,204 | Quote:
Did you Hard Reset or Format with Volcano | |
09-22-2014, 06:44 | #3 (permalink) |
No Life Poster Join Date: Oct 2010 Location: ahmdabad India
Member: 1424659 Status: Offline Sonork: 100.1648352 Thanks Meter: 142 | 1. Remove the updates for your Google Play - Go to the menu–>settings–>apps–>all–>google play store–> uninstall updates, then reboot your device. 2. Remove the cache for your Google Play - Go to the menu–>settings–>apps–>all–>google play store–> remove cache, then try to run your google play again. It is better to do a reboot. 3. Try to delete and re-install Google Play - In some cases, delete and re-install resolve this issue. 4. Check that Google Play on your device installed as system app instead of user app - If your Google Play installed as user app, try to install it as system app. There is a app that helps you to change it easily. “/system/app mover” Try this app (Sorry you have to find the app on your own!) 5. Download and install a different version of Google Play - Sometimes a different version of google play works instead of one that you have on your machine. so try to find a different version of google play(older or newer version) and try. br ashishsingh |
09-22-2014, 06:59 | #4 (permalink) |
Member: 1771086 Status: Offline Thanks Meter: 2,410 | MUKESH RAJ yes sir i do it already 5 time problem same .........i do fully flashing ...3 time another box i do format 5 time another box i do hard rest ...problem same i do uninstall all updates..in mobile after restart .....show all apps again .......... |
The Following User Says Thank You to fahad ali khan For This Useful Post: |
09-22-2014, 07:10 | #5 (permalink) | |
Full Erase And Flash Again \ No Other way ! | |
09-22-2014, 07:15 | #8 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | i dont know know which chip inside of this phone ... if inside EMMC chip then can make this kind of problem ... bcoz some emmc chip not format full user data area by data reset and format post volcano screenshot |
09-22-2014, 07:34 | #9 (permalink) | |
Member: 1771086 Status: Offline Thanks Meter: 2,410 | Quote:
Available Ports:COM16 COM22 COM23 Current Port:COM16 Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:6577 Hardware version:CB00 Software version:E201 Boot downloading complete! EMMC_ID:0x1501004E4A5330304D0069F069A511B1 EMMC_PRODUCT_NAME: SAMSUNG :0x4E4A5330304D EMMC_BOOT1_SIZE: 0x000100000 EMMC_BOOT2_SIZE: 0x000100000 EMMC_PRMB_SIZE: 0x000020000 EMMC_GP1_SIZE: 0x000000000 EMMC_GP2_SIZE: 0x000000000 EMMC_GP3_SIZE: 0x000000000 EMMC_GP4_SIZE: 0x000000000 EMMC_USER_SIZE: 0x0E9000000 Analysis of USB port... >>Flash writing complete. | |
09-22-2014, 07:52 | #10 (permalink) |
Member: 1771086 Status: Offline Thanks Meter: 2,410 | Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:6577 Hardware version:CB00 Software version:E201 Boot downloading complete! EMMC_ID:0x1501004E4A5330304D0069F069A511B1 EMMC_PRODUCT_NAME: SAMSUNG :0x4E4A5330304D EMMC_BOOT1_SIZE: 0x000100000 EMMC_BOOT2_SIZE: 0x000100000 EMMC_PRMB_SIZE: 0x000020000 EMMC_GP1_SIZE: 0x000000000 EMMC_GP2_SIZE: 0x000000000 EMMC_GP3_SIZE: 0x000000000 EMMC_GP4_SIZE: 0x000000000 EMMC_USER_SIZE: 0x0E9000000 Analysis of system files... PRELOADER: addr:0x000000 --length:0x040000 DSP_BL: addr:0x040000 --length:0x5C0000 MBR: addr:0x600000 --length:0x004000 EBR1: addr:0x604000 --length:0x004000 __NODL_PMT: addr:0x608000 --length:0x400000 __NODL_NVRAM: addr:0xA08000 --length:0x500000 __NODL_SECCFG: addr:0xF08000 --length:0x020000 UBOOT: addr:0xF28000 --length:0x060000 BOOTIMG: addr:0xF88000 --length:0x600000 RECOVERY: addr:0x1588000 --length:0x600000 SEC_RO: addr:0x1B88000 --length:0x600000 __NODL_MISC: addr:0x2188000 --length:0x060000 LOGO: addr:0x21E8000 --length:0x300000 __NODL_EXPDB: addr:0x24E8000 --length:0x200000 ANDROID: addr:0x26E8000 --length:0x29900000 CACHE: addr:0x2BFE8000 --length:0xA100000 USRDATA: addr:0x360E8000 --length:0x41100000 FAT: addr:0x771E8000 --length:0x72038000 __NODL_BMTPOOL: addr:0xFFFF0000 --length:0x000000 Format addr:0x3A0E8000 --Format length:0x3D100000 Read phone information success. Format range: Start Address: 0x3A0E8000,Format Length :0x3D100000 Flash erasing complete! |
09-22-2014, 13:03 | #15 (permalink) | |
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | Quote:
do factory reset by pressing key of phone... if not solve then write factory firmware this is working | |
